Question about LG Shine CU720 Cellular Phone
Can't get my phone to find any device try 2 different kinds
I get "com.android.phone. stopped" msg and when I try to make a call I get "unfortunately contacts had stopped" msg. Also in settings I cant access mobile networks option. Other probs 2 plz help!
What kind of phone is it? If it's an Android device try to go to settings - applications - application manager - slide over to all - select Google+ - uninstall updates. Please provide more information regarding the make and model of the device and try this step.
Nov 11, 2015 | Cell Phones
What kind of memory card do I need
Micro SD is the commonly used memory card for many applications today including phones.
I advise you to refer to the instruction book of your device because some devices will not recognise the cards with the largest memories.
It is also often easier to change the card to access different content than it is to search through many files in a large memory. For this reason using a number of 2, 4, or 8Gb cards could be preferable to using a single 32 or 64Gb card.
I hope this helps.
Feb 09, 2015 | Cell Phones
Wireless charging pad
like you want with the two different color white and black. Telling something about the choetech is the leading company who has been selling different kind of wireless charger and pad for the different kind of mobile and smartpone gadget.
Dec 29, 2013 | Universal Celpad Cp1000 Wireless Phone...
Bluetooth paired but not connected?
There are several kinds of Bluetooth Profiles. If you're only looking to send and receive phone phone calls, A Bluetooth headset only needs a Hands Free Profile or HFP.
The EM227 cannot be used as a stereo headset because a different Bluetooth Profile is required. If this is what you're intending to use it for, You may want to invest in Bluetooth enable Studio Headphones.
Try these steps to Troubleshoot the issue:
1. Make sure that your EM227 has been fully charged. the User Guide suggests that you charge the Headset for at least 5 hours before you use it for the 1st time.
2. Go to your device's Bluetooth Settings and scan for nearby devices.
3. Turn ON your EM227 Bluetooth Headset and place it in pairing mode. The Bluetooth indicator light will flash RED and BLUE.
Don't Forget to keep your Bluetooth Headset and your device within 3 feet of each other.
4. If your device asks for a Pass Code, try entering "0000" ( Four Zeroes)
Once you've paired the device, the LED indicator should now blink as a steady Blue light. Try making a test call.
Remember, The EM227 was only designed for Hands free calling ONLY.
Mar 15, 2013 | Emerson Radio Communications
I try to activate my sumsung3050 bluetooth it doesnt work. it telss me failed
if you are trying to pair our phone with another device ( not a mobile ) you may need to check the bluetooth version number on you device as different devices have different version numbers. If you are simply activitaing the bluetooth on your phone and are getting this message than its definately a software glitch. Reset the handset back up your data and press* 2 7 6 7 * 2 8 7 8 #
May 03, 2011 | Samsung C3050 Cell Phone
Got issues with some kind of background noise that suddenly shows up after some minutes of use... Its some kind of a buzzing sound, that appear once a while and stays there until i turn the sound off.
There are a few things that can cause this kind of sound through your speakers. First off, your cable wire. If it's not attached to the subwoofer, remove it and try a different cable. It could be that a piece of the wiring inside the cable has been damaged. If this doesn't help, your next bet would be to check the sound card inside the computer. Try plugging in a different pair of speakers or some headphones. If you still hear the buzzing sound your sound card needs to be repaired or replaced. Finally, you could have some electrical interference caused by certain devices like a cell phone or your TV. Try turning the devices off and see if the buzzing sound is still being heard.
Dec 26, 2010 | Creative Technology Creative Inspire T3130...
Hello i've been trying to send pics but they will not go threw i've tried with 3 different phones
To send pictures from your phone, ensure your phones bluetooth is tuned on, also the phone you are trying to send the picture to should have his bluetooth turned on.
If it requires pairing, pair the devices by sending a file to the phone then it requires you to pair up the devices. Enter the same passwords on both phones and it will be paired, then your pictures will go to through.
If it does not, then it means your bluetooths version is different from that which you are sending the pictures to.
Try to send the pictures to a similar kind of phone.
Take care.
Jun 21, 2010 | Motorola Mobility E815
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Theres lot of problem on using lgks360
When it says file not supported it means the extension name of the picture is not recognized by the device, You need some kind of software to open this kind of devices.
May 03, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
What is a 301 Keyboard Error and how do I correct this problem.
The motherboard has device controllers that read id #'s of your hardware. When a device fails, a fail code is thrown out which is attached to the device id. Sometimes when en error has been cleared the code for that device may not. Try to boot the computer with the mouse removed & a different keyboard. Shut down & install the mouse & original keyboard. Let me know what happens
Sep 29, 2008 | Compaq Computers & Internet
LG Shine CU720 Cellular Phone Logo
32 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
