Question about Braun KSM 2 Electric Blades Grinder
Blade replacemen braun grinder
I have a ksm2 braun coffee grinder I need a how to on blade replacement i have the new blade
  • 4 Answers
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Posted on Jan 12, 2008
Braun ksm2 blade slows and does not grind
Yes, unscrew the blade, inspect for any gummy material, hair or any other material that might cause it to slow down, remove it,, and replace the blade. If that doesn't solve the problem, you'll have to diss-assemble the grinder, check the carbon brushes to the motor, to see if they are very worn, replace if necessary and after a complete inspection of the motor, shaft, etc, re-assemble the machine. That should do the trick.
Oct 05, 2014 | Coffee Makers & Espresso Machines
Where can I buy the plastic cap nut that protects the threads on the top of the blade shaft? Mine came off after 15years while grinding beans and is not useable any longer.
There is no plastic nut, it's all one piece of plastic. You need to replace the blade. If you Google KSM2 replacement blade, you'll see who's selling it. Or if you have small appliance repair shops in your community, they may have it. I just bought one a few days ago.
Sep 16, 2012 | Braun KSM2-WH Electric Grinder
Where can I buy a new blade for a Braun coffee grinder Model KSM2 ?
Try ereplacement.com. There are blades listed for $3.49 but I have never ordered from them.
Aug 19, 2012 | Braun KSM 2 Electric Blades Grinder
The tiny plastic piece that pushes the wire to complete the circuit has broken. Where can I get a new one (that won't break)?
Make one youself out of quick steel putty. It is a 2 part epoxy putty that when mixed and shaped, it hardens ito any shape you need. It also bonds to surfaces like super glue.
Feb 18, 2011 | Braun KSM2-WH Electric Grinder
Switch always "on"
Trying to fix the problem is complicated and would require pics and step by step disassembly? Athe simplest way would be to pick up a switch at a hardware store and put it in line. They are used most commonly for lamps but work well on these small motors.
Jul 29, 2010 | Braun KSM2-WH Electric Grinder
I have a problem with the switch. KSM2
It is good to repair the switch but it is best to have it
replaced. You may be able to repair it but the problem
will probably recur. However, you are in the best position to resolve the solution either to repair or replace the switch.
Oct 04, 2009 | Braun KSM2-WH Electric Grinder
How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
Jul 13, 2009 | Braun KSM 2 Electric Blades Grinder
Blade Change Braun KSM2 Coffee Grinder
There is a small slot on the bottom for a flat screwdriver to lock the shaft in place. Then unscrew the blade.
Mar 25, 2009 | Braun KSM2-WH Electric Grinder
Braun KSM 2 Electric Blades Grinder Logo
773 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
ellipse0904
Level 1 Expert
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
