Question about Robinair Side Wheel Manifold Gauge Set
Have low side manifold pressure, can not reduce it on a robinair 134a machine. also keeps freezing up
  • John Wolfe
    John Wolfe May 11, 2010
    It sounds like a failed solenoid. I need more information, Model number, serial number, and date code. What function does it "Freeze up" in?
    President:
  • 180 Answers
You have to change this manifold gauge set.because it's sound like low side valve is damage.
Posted on Nov 12, 2009
Machine won't recover, it gets stuck on "clearing in progress" Also won't vacuum, it says that "pressure exist press any key to continue" Your help would be greatly appreciated
I had a similar problem with a Robinair 17800b. The machine got stuck in Clr or (Clearing) while changing from R-12 to R-134a. If the tank (R-12 or R134a) does not have at least 10 pounds of refrigerant in the tank before you change to another refrigerant, the machine will stay in the clearing process. I called tech support and they walked me through a process that resets the machine. The reset involves entering a code while in r-12 mode, then removing all hoses and switching the switch to R-134a mode and entering another code. The call to the tech line took about 5 mins. The number I called 1-800-822-5561.
Aug 18, 2015 | Robinair Cool Tech 34700Z Recovery,...
What are correct pressure readings 134a
-Depend on the unit. There should be a label there to tell on High and Low number.
Good luck
Mai
Aug 22, 2014 | Robinair R-134a Manifold Gauge Set A/c...
Hi, my robinair 34700Z dispays "Low Pressure system" when I try to recover and when I continue by pressing start, it displays "equalizing hose" and doesn't continue on the recovery...
You can try the following:1# Check (In main manifold assy.) recovery solenoid (No-1) and make sure coil is not burne or may need to rebuild. If so,replace new coil or rebuild solenoid flunger.2# Check (In small manifold back side of the machine) Inlet low & high side solenoids (small solenoid's No-10/11, and No-13/14) is receiveng power & opening properly.
Also you may need to calibrate pressure transducer or replace new one.
Hope this will help you. Good luck!
Mar 19, 2011 | Robinair Cool Tech 34700Z Recovery,...
Is there a universal gauge set for all types refrigerant
The most common manifold are only for r-12 and R134A. Because of the pressure differences between that and R22 and R-410A ( and the manufactors make more money by keeping the types of manifolds seperate). I haven't seen a universal manifold that would cover all types freon.
Feb 05, 2011 | Robinair R-134a Manifold Gauge Set A/c...
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34700 recovery problem
It sound like one of the pressure trunsducer is not working or disconnected from the manifold assy.or from ISV tank.Please check Low,High and ISV tank pressure transducer
Jul 08, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robin air recovery station for R12, My Question is Can this machine be converted to recyled 134A, By changing the filters? Email to tdrworks@yahoo.com I thank you in advance. Sincerely Santos
Sorry you can not make this only with changing spin-on filter.because have to also change other things such as service coupler,ISV tank,manifold gauge etc.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
My 34700Z is not discharge low side existing pressure, wen i select vaccum the low side hose have pressure and stop to make vaccum
Please Check the following 1# Check ISV tank may overfill,if so manually discharge extra pressure from the tank.2#Check High & Low side small recover solenoid (in small manifole assy.) it's may neet to rebuild.3# Check Recover/Vacuum/charging (in main manifold assy.)solenoid,rebuild if need.4# Check ISV tank liquid hose is connected properly & make sure it's not too much tight OR loss.5# Check high side coupler is opening properly.Hope this will help you to solve the problem.
Apr 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
ROBINAIR 34700Z ALWAYS FAILS VACUUM CHECK AND WON'T INJECT OIL.SAYS PRESSURES EQUAL.
Please check the following: Low side manifold gauge is going to -13"HG while you recover refrigerant from the vehicle.If low side gauge not rich to that lavel then vacuum sensor will detect pressuer &
it will stop you to make vacuum until you fix the problem.If it happen you may nee to rebuild/replace one or more of this solenoid.1#Vacuum solenoid 2# Recover solenoid.3# Recycle solenoid.Also check Low/High side small solenoids ( In the small block assy.)
If all of this solenoids working properly then check Vacuum pump capacitor & vacuum sensor.Hope this will help you to solve your problem.
Apr 09, 2010 | Robinair Cool Tech 34700Z Recovery,...
How refill my tank of freon 134 in my machine ?
Fix low side coupler to R134a refrigerant sorce (new refrigerant tank with up side down & tank valve open) tank.Open low side manifold valve & close high side manifold valve.press tank re-fill or recover botton & fill as you want.NOTE: Max.cap.50 LBS or 23 KG.
Jan 21, 2010 | Measuring Tools & Sensors
Robinair  Side Wheel Manifold Gauge Set Logo
87 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
