1996 Jeep Cherokee Country Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1996 Cherokee serpentine belt no moving.
1996 Cherokee serpentine belt not moving. Crank/waterpump pulley turning trying to burn belt
Anonymous
Level 2:
Sergeant:
  • Expert 206 Answers
  • Posted on Sep 24, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
206
Questions
Helped
106329
Points
597
Sounds like you have something locked up.
Take a picture/draw a diagram of serpetine belt routing.
Remove the belt, then try turning each individual item the belt powers to see which one is locked up.
I'd start with the AC Compressor first, then alternator, the belt tensioner, power steering pump, and whatever else is powered by the belt.
3answers
None of my pulleys will turn on my jeep Cherokee larado
with the belt on or off? If when off, anything not turning means the bearings are probably frozen. The units would need replacement. Its a coincidence that all are not turning at the same time. CHECK CRANK & CAMS WITHOUT THE BELT. IF THOSE ARE N/G YOUR STARTING TO LOOK AT A MOTOR REPLACE OR SERIOUS REPAIR.
1996 Jeep Grand Cherokee will not start. Serpentine belt broke, so I replaced it, but now it will not start even with a jump. only clicks. Starter?
Maybe.
But what caused the belt to break ?
You might want to make sure the crank will turn and that the engine is not locked up.
If the crank turns, you would need to check for battery voltage at the starter.
2helpful
2answers
I need a diagram for replacing a serpentine belt also are all the pulleys supposed to move that hold the belt on
There were 4 different engine sizes for that year truck.
It looks like the belt route is the same for all.
I hope this helps. God Bless
2helpful
1998 grand cherokee 4.0 eng. crank shaft pulley,is there a back piece for the belt to go on?
are you talking about the serpentine belt or the timing chains, the serpentine belt is what drives the alternator,power steer,water pump, and goes around a few idlers. and around crank pulley that is in front of harmonic balancer. Did the belt fall off? is the pulley missing? cause it should be very self explanatory and visual.
3answers
I have a 1996 jeep grand Cherokee. The belt does not stay line up on the pulleys. Make a squeling noise. I believe it might be some bearing. I do I diagnose? What causes that
You will need to remove the belt and check each pulley and idlerfor play/ slop
My best answer is you will find an idler pulley that is shot
1helpful
2answers
Pulleys and driveBelt move freely when engine off, but they dont
sounds to me like the belt is just sliding on the crank pulley. Could be a separated harmonic balancer. Check the big pulley on the bottom.
13helpful
2answers
Te magna waterpump changeover
MAGNA 1996 TE you have to pull down all covers of front of motor remove rh wheel and inner plastic protecters to access crank wheel remove crank wheel. rh engine mount and two outer belts lower/lift engine to remove timing belt pulleys ect.remove timing belt to access waterpump lots of labour can email photos if any one needs an idea .of whats involved when replacing water pump. best get a timing belt kit and replace belt ,pulleys as well. then good for 100.0000 kms and plugs as well platium ones by doing on your own can save 800 to 1000 dollars just be carful not to move pulleys on timing belt . good luck i posted this after i had no response .a desiel mechanic guided me though the ordeal a lot of labour for a waterpump it took me 8 hrs straight to do . hope this is useful i didnt need timing kit just belt total cost if you do job $350.00 i got quoted $1500 by mechanic
$25 COOLANT
$300 TIMING BELT KIT OR $100 FOR BELT ALONE
$95( WATER PUMP NON GEN SUPERCHEAP AUTO)( GENUINE MITS $300 TOO MUCH$$$)
$90 PLUGS PLATIUM
$30 OIL
$7 OIL FILTER
$10 GASKET GLUE
1helpful
Waterpump pulley removal
Pulley unbolts from the front of the pump. Remove belt after you loosen the pump bolts. you can lean on the belt to keep the pulley from turning as you break the bolts loose.
Serpentine belt
The pulley's aren't supposed to spin freely with the belt on. The belt connects all the pully's to the crankshaft, which does not spin freely because it is attached to the pistons inside the engine. To turn the pulleys, you have to turn the crankshaft, which in turn moves the pistons inside the engine up and down.
11helpful
4answers
1996 Jeep Cherokee Classic with serpentine belt and fan problem or water pump?
Hey Dougnchico,
I'll bet your car died. And it over heated, And the battery was flat
, And the steering went out and every other system run off of the belt.
This is for anybody who has had trouble getting a serpentine belt on. It's easy and doesn't require a prybar.
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • Get the belt around all the pulleys except the A/C compressor or Alternator.
  • Locate the tensioner pulley. It's one of the smaller ones and is mounted on a spring loaded arm. It's job, as the name suggests, is to keep the belt tight. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Mike
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
