Question about GE Profile JGS968 Gas Kitchen Range
Explosions Half of the time that I use my oven, I get a gas explosion inside it. It's an intermittent problem. After I turn on my oven, it explodes after a minute or two. It makes a very loud exploding noise and blows the door open and then it snaps closed. The first time it happened, I thought a car hit my house! The temp never reads above 100 degrees when this happens, which is the default number it reads when you turn it on. I have had a GE repair person here 6 times for this same problem! He has replaced the igniter, gas regulator, and oven burners. It's still happening. This problem has been happening since we got our range 3 years ago, it's never worked properly. Does anyone have an answer as to why this is happening? Every time the repair guy leaves, he says it's fixed. But now I'm afraid every time I have to use our "new" oven.
  • 2 more comments
  • JulieK Dec 17, 2007
    The "valve control" for the oven was already replaced. It's part number wb21t10014. Isn't that the "gas valve"?
  • JulieK Dec 21, 2007
    Ok, so the guy came to fix the oven again. He said that he found out that the reason it's exploding is because it's starving for secondary air. The reason that it isn't getting enough air is that we took the legs off the oven so it would fit properly...flush with the counter, since it's a slide in and the stove was too high. Adding the legs back raised the stove about 1/4 of an inch from what it was. Does this sound legitimate?
  • baudhuin Jun 04, 2008
    Our GE is a PGS968 slide in and we've also had to remove only the front legs to get the unit to align with the countertops. Since April 2007, we've had five explosions. Ignitors, controls, and gas valves have not fixed the problem. They're going to be back again to see if there's gas building up. Slim chance that will show anything. If it was a gas build up, as soon as there was power to the ignitor, you would have an explosion. Ours occurs after about 3-5 minutes (again with the display showing 100).
  • kvandegevel Jul 10, 2008
    I have exactly the same problem. Temp does not go up or goes up slowly and then boom! Technition is coming back for the fourth time in 1.5 years. He has also replaced everything that you mentioned and last time said it was likely a problem with our gas line and to call the energy co. When I did this they laughed at me as all of our other gas appliances are working just fine.
  • 89 Answers
Gas valve needs to be replaced. You may want to pay a pro to handle this one! (gas is nothing to play around with) Goodluck!
Posted on Dec 16, 2007
  • Brian Gillespie
    Brian Gillespie Dec 17, 2007
    Ahh, thats the valve I would have replaced first but there is another valve that feeds that one. Its also located inside the oven (part #WB19T10033)....
  • Brian Gillespie
    Brian Gillespie Dec 21, 2007
    Hmmm.... I will have to get back with you on that one. I've never heard of that but tomorrow I will ask another Wiz in this field and see what he says...I'll touch back with you before 2:00pm (12-21-07)
After turning on either of the ovens in my Viking gas range, they will intermittently make a hissing sound followed by a series of popping sounds with a gas odor and they are very slow to heat.
call a gas fitter as you have a problem with the jets/ supply that is creating a dangerous situation leaving unburnt gas ( you can smell ti) that could cause an explosion
Dec 21, 2016 | Viking Kitchen Ranges
Will This blow up?
Dont start the oven, the burner valve is faulty, the appliance is not safe call in a repairman.
Aug 01, 2008 | Tappan TGFS_63 Gas Kitchen Range
Kenmore c970-657084
Explosion from what? If this was a gas explosion then you should have a professional look at it. If this was a power supply issue then you will have to replace the power supply board.
Dec 02, 2013 | Kitchen Ranges
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 14, 2012 | Bosch & Tankless LP Hot Water Heater
Pentair minimax nt explosive ignition
Problem is an obstructed gas oriface. The burners light from the burner closest to the pilot assembly out like a dominoe effect. The explosion is because the gas has to make its way over to the pilot from a further burner thus filling the firebox full of gas before it ignites. This blockage is most commonly from a spider web inside the oriface itself. Pull the burner tray, remove the orifaces from the tray and look through each one cleaning them out with a toothpick from the backside. The orifaces should be threaded on the gas line coming off the gas valve (looks like a silver box inside the front panel)
Feb 16, 2012 | Pentair Minimax NT Heater
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
Small oven explosions
check and replace your gas regulator to your burners in your oven
Mar 16, 2009 | Thermador P304CS Gas Kitchen Range
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Oven igniter causes small explosion
Sounds like the ignitor is worn or mispositioned or the gas mix is wrong.  Could also be a worn burner.  Don't do this yourself unless your fire insurance is up to date.
Nov 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGS968 Gas Kitchen Range Logo
387 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
