Question about Western Digital Computers & Internet
My hard drive has stopped working! I checked power supply and it is working fine, when plugged into drive and turned on, the blue light flashes briefly on the drive then goes off again as does the light on the transformer on the power supply. when power supply is not connected to the drive the green light stays on like usual. it does this wen both plugged into the usb port and not. please help!
  • Anonymous Mar 13, 2014
    I have a shortage in the hardrive in the port that connects the power supply. The light does not flash but sometimes i can feel it spinning inside. Any solutions? Where can i at least get it serviced?
    President:
  • 1,015 Answers
Could be a bad transformer on the power supply or a bad drive. You could check the voltage coming from the transformer and verify that it is the proper voltage using a fluke meter. You could also dis-assemble the hard drive housing and try installing it in the computer and check if it is working. If you install it in the computer and the drive is not found then the drive is probably bad. If the drive works in the computer then get a new transformer.
Posted on Sep 24, 2009
My iomega hard drive Model No GDHDU has just stopped working the power light isnt on but the power lead is fine I CAN`T ACCESS ANYTHING PLEASE HELP
Your hard drive is not getting the power from the port u r connecting to. So please check it with other port . If the same behaviour then it is physically damaged and u have to take it to the service centre
Feb 01, 2011 | Iomega (33150) Hard Drive
I connect my Lacie d2 quadra to my mac with firewire 800 and it works fine, but when I connect the same hard disk with esata, it appears on the desktop screen, but the blue light won´t stop...
Hello.
I have had simular problems with one of these. It can be due to the drive not starting up or shutting down properly or a powers issue.
I woud recomend dissconecting all leads from the back of the hard drive.
Now plug in just the mains power. Now turn the drive on and let it boot up until the light stops flashing. Let it stay constant for a while, now press the power/led button to let it shut down properly on it's own.
Now turn of your mac. with the hard drive still OFF, connect the fire wire to you're mac and HD. Now power up the Mac. If the HD does not power up on it's own, turn it on now.
Hopefully all should be ok now.
If not, try to test it on a PC. It may sound strange, but it can make a difference. Now do all the above again.
Any Luck?
Ok another thing is to try a psu. Hopefully you know someone with a drive you can ask to test their power supply with.. Try all of the above things again? Any joy? if it all workd ok with their power supply and not your's, your mains transformer is bust. It's caused by a capcitor that blows (quite common). If your drive is recent, you may be able to harrass Lacie for a new one, if not I managed to get a Lacie psu from ebay for around £25.00+p&p on ebay.
A final thing to check is what firewire version your mac is against the firwire version of the lacie. Sometimes this can give issues.
Hope this helps.
Jan 13, 2011 | Computers & Internet
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
Flashing power light.
Have you tried a differnt usb cable if that dos not do it get back with me and I will walk you though checking it out
Jan 09, 2010 | Computers & Internet
When i plug the hard drive in, a blue light flashes but the dard drive doesn't turn on.
First check your usb port of computer and usb csable are working fine.
Then go to my computer proeprty then hardware then device manager then uninstall all usb drivers then restart the computer then check
Aug 20, 2009 | Western Digital Elements powered by WD 320...
My WD Elements 640GB Wont turn on.
I had the same problem. I fixed this by leaving the power supply connected with the wall socket for about 15 minutes, without connecting it to the external hdd. After that I connected the power supply with the external hdd and it worked perfectly. I hope this helps for you too!
Aug 02, 2009 | Western Digital Elements powered by WD 320...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
External hard drive wrong power supply was plugged in
The power circuits in the external hard drive enclosure may have burnt out or the fuse may have blown. Its unlikely your hard-disk is itself damaged.
You may remove the actual hard-disk from the enclosure and put it in another and access the data.
All the best!
Jan 29, 2009 | Computers & Internet
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Computers & Internet Logo
620 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
