Question about X-10 X10 Smart Repeater Remote Controls
X-10 Pro plug in pool lighting controller worked for awhile, then quit, the pool contractor said it had to be plugged into a certain outlet I had, but it still doesn't work. Do I have to drain the pool down to the light to replace it, to see if the the problem is the light? Also, if I purchase a remote to replace this, is it easy to install and is it compatable? We have had the pool for 4 years, and have not had a light for 3 1/2 yrs of that time, Very frustrated, Thank you Barbara from Redding, CA
2 Suggested Answers
SOURCE: my X10 Pro pool lighting controller worked for a while, then quit
Most likely the pool motor or other devices are making the powerline noisy. I suggest either getting an x 10 tester or unpluggin hosehold devices until you find teh source of the noise.
Stephen Lerouge
Home Automation Inc,
Southwest territory Manager
Posted on Mar 21, 2009
Can two separate convection units (microwave and oven) be combined/joined into one cord and plugged into one outlet and BOTH work efficiently? The contractors I hired combined all wires to both unit
You need to have the contractors return and troubleshoot the problem free since they told you they both worked when you purchased them. There's an implied warranty here. The two ovens should have been tested before the contractor left your house to prove they both worked together.
Dec 21, 2014 | KitchenAid Microwave Ovens
The OH Light keeps coming on although the temperature never exceeded 100 degrees.
check your recirculation pump it sounds like it isnt working or plugged filters
Oct 16, 2014 | Pool & Spa
Just quit working. When plugged in, the microwave
you must check the fuse inside of the micro wave
this has a value of 10 or 16 ampere.
if it is a glass fuse you can see when it is defect otherwise you have to test it and replace it
check also the capicity for malfunction, with tester you have te have a value bethween 0.85 and 1 uF
Feb 15, 2010 | Kitchen Appliances - Others
How do I connect up a hayward pro grid de4820 to a pool pump
motor gets hooked to bottom ,top is outlet back to pool there should be a bottom drain plug hose to pool goes on top return and on pump inlet
Jul 13, 2009 | Pool & Spa
X10 mini controler will not turn off pool light
the unit is probably transmitting but the receiver on the lights is not getting an acceptable signal.
try placing your controller on a line closer to your main electrical panel.
Unfortunately x-10 technology is very unreliable its convenient but its also a pain in the ****.
Do the basics make sure the controller is close to your panel, make sure its not plugged into the same circuit that your appliances, computer or electronics are plugged into as they generate RF interference.
Smarthome.com sells several X-10 boosters, if your home has a 2 phase power get one that plugs into a 220v outlet that will "bridge" THE TWO PHASES.
May 09, 2009 | X-10 (MC460) Remote Control
My X10 Pro pool lighting controller worked for a while, then quit
Stephen Lerouge
Jan 14, 2009 | X-10 X10 Smart Repeater Remote Controls
X-10 X10 Smart Repeater Remote Controls Logo
82 people viewed this question
Top X-10 Televison & Video Experts
Are you a X-10 Televison and Video Expert? Answer questions, earn points and help others
