Question about Philips 42PF7320A 42 in. Plasma HDTV
Horizontal and vertical lines
My parents philips 42pf7320/37 plasma tv has a bad picture. my boyfriend and i recently acquired it in the hopes we could fix it. the screen has many lines going across and up and down it. the color also bleeds. light colors tend to bleed up and down the screen. lastly the hue is very red around these abnormalities. we have looked and the power board and what we believe is the video board for bad solder joints. we haven't found anything that looks "wrong" yet. i was hoping someone here might be able to speed up our hit and miss process and send us in the right direction of what we should be looking at. if anyone has pictures of what we are looking at with labels pointing towards the different boards and parts (or even pics with a REALLY good discription of where things are located and what they are) that would be extremely helpful and much appreciated. thanks
  • Anonymous Feb 10, 2008
    horizontal lines across screen
  • ed bohannon Sep 05, 2008
    I have a similar problem, my Tv was purchased in 12/05, model 42pf7320a/37 ; while veiwing one afternoon, I looked away from the screen and when I looked back I notices verticle lines throughout the screen, it appears as though the white and red lines are distorted green appears to be ok. Is there a solution that is cheaper than buying a new TV?
I am having the same problem with my TV. I believe that the Y-Buffer Driver IC's are bad. There are two small boards on the left hand side(looking at the TV from the back) with 6 small heat sinks on each of them. If you look closely at the boards, it ill say Y-BUFFER on them. There are ribbon cables that run from them to the Plasma screen.
In my TV, several sections of the screen do not have lines in them. These driver IC's are not hot, however the sections of the screen that have lines in, the drivers are hot to the touch. In order to verify that the chips are indeed bad, I am going to swap one that I think is bad with a good section and see if the problem moves. If this is the case, the boards can be swapped out, or chips replaced depending on what kind of parts I am able to find. The chip that they use is SN755867. I haven't been able to locate a source for the chips yet.
Posted on Jun 29, 2008
  • jr8888 Jul 16, 2008
    The problem turned out to be these SN755867 IC's on the Y-Buffer boards. I was unable to remove the IC's using a solder reflow station at 240C because of the RTV glue used to attach the heat sinks did not soften at this temperature. It may be possible to remove these IC's with a lot of work by lifting individual pins and prying the IC off. I am not sure if there is a heat sink slug in the center of the IC. Tesla411 as well as Sierra IC claim to stock the replacement IC's but didn't respond to my request for quote.
    Using a refrigerant, I sprayed the heat sinks on the PCB which cooled the chips down to about -50degrees Fahrenheit. With the chips at this temperature, most of the missing lines on the screen returned briefly. I ended up replacing both the upper and lower Y-Buffer boards and this fixed the problem. Due to the high voltage( about 430V) through these IC's ;I don't know how long the replacements will last. I only had horizontal lines on the screen and not vertical as mentioned above.
    Problem Solver:
  • 12 Answers
I have a horizontal line through the tv with no picture
By now you've probably replace this with a Flat Screen LCD, LED or Plasma unit. But the answer to your original problem is a loss of vertical drive. Possibly just a bad solder joint @ the vertical IC.
Apr 12, 2012 | Memorex MT2274 27" TV
Horizontal lines on Samsung Plasma
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $150 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair if you don't have any knowledge of repairing it.
Goodluck...
Feb 13, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
The picture is distorted by both vertical and horizontal lines (different colors; pixelated)
A distorted picture display soon after the Plasma TV is powered on has two indications. First, a picture display of pixels when the TV is powered on is usual prior to signals of video movies are acquired from broadcasting station. The movie from braodcasting station should display without noticeable objects of distractions. For example, the movie displeyed on the TV without obstructions is indication that the problem is from the display set. Alternately, movies with poor capability to display on the set is indication that the media from which motion pictures are acquire from is malfucntioning. For example, a TV connected to cable network or disk network or satellite broadcasted signals with receptive compromises are diagnosable from two areas. First, a clarification from the network station that has setup connectivity of devices. Perhaps a device in the setup is malfucntioning. Second, attempting the adjust the phsical connections that are attached to the TV is capable of resoving the problem. Refer to the user guide for what is default expectation on powering on. Thereafter consul technical experts if required. Good luck
Jan 08, 2011 | Philips 42PF9630A 42 in. Plasma Television
NTV Scree
All plasma an lcd tvs have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 28, 2010 | Televison & Video
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
Plasma has half screen good and other half no picture just colored lines
bad buffer board email me and tell me if there horizontal or vertical these board are about 30. to 100. redscomputers@gmail.com
Oct 19, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | Philips 27PT6441 27" TV
Philips 42PF7320A 42 in. Plasma HDTV Logo
921 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
