Question about Zanussi FJS1225W Front Load Washer
Hotpoint wd420, error code "pressure switch stuck on empty"............found lots of debris in sump, all cleaned out including pressure bottle and tube, still same, new pressure switch fitted, still same. what seems to be happening is the machine is pumping out as it's filling and not allowing any water level to build up inside pressure bottle...any ideas?
  • simon_2_ball Sep 24, 2009
    it abrubtly started doing this a week or so ago, there were no intermittant issues prior to this........it is an electronic timer, what i have also just done is placed the drain hose into the kitchen sink to eliminate syphoning, then, to try and fool the machine, and to get some water into the drum to activate the pressure switch, i fed the drain hose into the soap drawer, but the same thing happens (if i squeeze the rubber sump hose when there is water in there, i can hear the pressure valve clicking, but the pressure bottle simply will not fill with water, i have had the sump pipes off about 6 times now, checking for leaks, missed blockages etc etc, my conclusion is that the pressure bottle does not need a significant amount of water in it (i can't see any when shining a torch, but can clearly see water in it when i was cleaning it) and that the main PCB is throwing a fit.....and a replacement is too expensive to even bother replacing the main PCB..........(i forgot to add, when the machine goes into fault mode, the fan on the dryer also starts up.)
    so in summary, the machine will run for about 1 min, on any cycle, any temp, when the fault light comes on ("pressure switch stuck on empty"), the machine continues to drain, and the fan for the dryer comes on.
    thankyou.
  • Zanussi Master
  • 909 Answers
Is it an electronicor mechanical control?When did it start doing this? If mechanical, does it continue even if you forward the timer?
Posted on Sep 24, 2009
  • Terence Fourie
    Terence Fourie Sep 24, 2009
    Actually, without boring you with long detail, i feel the board needs to be relaced.You just need to concider if it is viable or not.
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
Error code al03
AL03 indicates a time out on drain fault. Either there is a restriction or blockage on the drain side of the appliance or on the pressure side.If the machine empties ok you need to locate the pressure switch, remove the thin tube and blow back into the sump to try and clear the restriction. If the machine isn't emptying or empties slowly you need to clear the restriction/blockage in the drain hose, pump or sump.
Apr 03, 2010 | Hotpoint Dishwashers
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
Stops near end of cycle and on/off light and drying high heat light flash
error code f08-htr relay stuck-ckeck htr not open citcuit-connections on board are clean especialy botton connecters-if still throws error then req new board
Nov 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f16 N/A
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
Sep 13, 2009 | Hotpoint Washing Machines
Hello, I have a hotpoint aquarius WD420. The machine first started playing up by not pumping out properly, and aborting mid cycle qith an error code, after the first pump out. I removed the filter / float...
Did the circuit board get wet?
Its behind the fascia panel.
You will need to remove the top cover to see.
Screws are at the back of the top cover.
Remove them and slide the top backwards to get the top off.
Look for any water marks.
Best luck
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Zanussi FJS1225W Front Load Washer Logo
577 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
