Question about Bosch 24 in. SHU43 Built-in Dishwasher
Incomplete draining of water - Bosch 24 in. SHU43 Built-in Dishwasher
  • 8 Answers
Check if the outlet hose is clogged by disconnecting the tail end that is connected to the garbage disposal unit or kitchen sink. You should also unscrew and check the filter on the bottom pan of the dish washer and remove any food particles etc.
Posted on Sep 28, 2009
The top is locked
Hi Janice
very descriptive "the top is locked"
Samsung model
Check rear of manual for problem help
Probably being held with an electrical solenoid catch because a cycle is incomplete.
Could be full of water. Logic chip says "don't open"
These modern smart devices can be a pain when things go wrong.
Hold drain hose to floor & see if it drains out.
Jan 08, 2016 | Washing Machines
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
Hoover H160E - stops with lights flashing 4 times (cyclic)... suaully before aspin cycle... appears to be incomplete drain (drains until no water viisble in drum - but still significant water at drain.....
I would definitely change the pump motor judging from your clear symptoms and observations!
It's probable that the motor isn't running efficiently, just enough when helped by the 'gravity' of the full drum but struggles once that is minimum.
Go for it ;-0)
John C
Feb 26, 2011 | Hoover H160E Front Load Washer
Incomplete washing cycle. Water will not drain
Check the voltage to the drain pump, if present the pump is not working and must be repaired , cleaned and set back.
if there is no supply to the drain valve/pump, the program controller is faulty.
Sep 27, 2010 | AEG Lavamat 72640 Front Load Washer
Kenmore Front load 44832. My washer works fine but after it sits over night there is about an inch of of water in it in the morning. I closed the valve on both the supply lines and this seems to solve the...
may be that or you may try lowering the drain line, sometimes this can happen if the drain line is too high causing incomplete draining and backwash of the drainwater
Jan 05, 2010 | Kenmore 44102 Front Load Washer
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Slow and incomplete flush. material does not go down or some comes back.
Clean out the holes under the rim where the water comes in from the tank. Mineral deposits can clog these. A stiff piece of wire (coat hanger) will work.
Also, if the toilet has the siphon hole at the front part of the bottom of the bowl, this can get clogged with mineral deposits. These deposits can become almost rock-like and can be very difficult to remove. Try using a short screwdriver and break these loose. Water must flow freely from this hole for the toilet to flush properly.
Oct 10, 2009 | Home
Viking VUD141 advances through the cycles but won't drain water
The unit should be installed with a high loop in the drain line at the rear of the unit. If this is not in place it can cause the drain water to run back into the unit. If there is a partial blockage it could result in incomplete drain. Try disconnecting the drain line below the sink and run the unit to drain into a bucket see how it drains. would be a sign as to how free your drain line is.
It could also have defective drain pump
Jan 10, 2009 | Viking 24 in. Professional Series VUD141...
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Incomplete water emptying following spin cycle
your pump is on its way out inside they have a small fan which pushers the water out if that is lose than the pump has to be replaced common fault
Dec 25, 2006 | GE WJRR4170E Top Load Washer
Bosch 24 in. SHU43 Built-in Dishwasher Logo
228 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
