Question about Hitachi 80GB IDE Hitechi DeskStar 7K160 7200RPM 8MB HDS721680PLAT80 0Y30001 80 GB Parallel Hard Drive
What settings do I need to turn an 80gb into an external drive
  • 557 Answers
If using as an external USB drive it needs to be set as a master.
Posted on Sep 24, 2009
I have a Fujitsu 80gb Sata hard Drive (2.5) which I have an adapter to use as a external Harddrive. However my computer and others only recognise it as a 14 gb drive. How do I get the full 80gb?
It seems this is caused by setting jumpers on your hard disk. Checkand return it to the correct position. Normally, your disk should be inthe position of Master or Slave.
Jan 16, 2011 | Fujitsu 50PK 80GB SATA 5400RPM 2.5 IN...
Computer dont recognize hard drive
you may need to change the jumpers settings on the hard drive...its a little black pin cover try moving it over if its (:) or try (..)
Jun 23, 2010 | SimpleTech Pininfarina 80GB External USB...
80gb ultra travel drive is not recognized by computer when the hard drive is attaced to it. the main board is just fin that plugs into the usb but when I attach the hard drive to it the computer no longer...
One thing is if the drive draws more than the alloted .5 amp from the USB it the motherboard will turn off the power. SOME of these drives require a 5 volt external power supply. Some of them rob two USB ports to get adequate power.
Jan 15, 2010 | Memorex Ultra Traveldrive - 80GB 80 GB...
Moving my Iomega® HDD 80GB USB 2.0 External Desktop HD
You have to create a admin. user account on your computer. You do this from user accounts.
Nov 20, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Western Digital 80gb HDD Fails when installing OS
Try changing the jumper settings to make it the Master instead of the slave drive
Mar 23, 2009 | E-Machines eMachines Desktop PC
Seagate 80GB storage. drive not found. lite on front of drive blinking
check your usb cable from 80gb hard disk to the pc.
is the 80gb hd detected by the pc? what os you are using for the pc? check the external hd inside maybe it is not properly connected
Mar 31, 2008 | Computers & Internet
Using as startup disk
If you used Acronis, you need to clone the 30Gb and not backup. In doing so, the booting information is likewise copied to the 80Gb, whereas back up is simply copying contents (that you specified) hence will not boot and not be active.
Pls remember that by cloning, Acronis would erase the partition (and contents) of the 80Gb. At certain settings, it would also split the 80Gb into 2 partitions; 30Gb & 50Gb. Further, verify that the 80Gb is "Set Active" and partitioned as a Primary and not Logical.
As to your other concern of installing, in some instances, some not so recent motherboards' BIOS/CMOS will not recognize the 80Gb. Other than that, you were doing it correct; new 80Gb as primary/master with jumper to the pins nearest the IDE cable, any other device (CD ROM or another HD) should be set as primary/slave (SL). Additionally, pls verify that your motherboard auto-detected your new 80Gb as your primary boot media (settings in your CMOS/BIOS).
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 03, 2007 | Samsung (SP0822N) 80 GB Hard Drive
Hitachi 80GB IDE Hitechi DeskStar 7K160 7200RPM 8MB HDS721680PLAT80 0Y30001 80 GB Parallel Hard Drive Logo
145 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
