Question about Dell PowerEdge 1600SC Server
Ps2 keyboard and mouse don't work. usb works fine
  • 37 Answers
Assuming you have checked in setup that the PS2 is turned on the other option is to re-flash the bios .
At some time someone switched the mouse and keyboard and started up the computer this can cause you to need to re-flash the bios most likely the keyboard chip needs to be replaced sorry to bring bad news .
Dell seems to have this problem yet the USB works is good where most modern keyboards and mouse are USB.
Purple is Keyboard if not color coded the closest to the outer side of case is the keyboard.
Good luck hope this helps you
PS. You may try setting the jumper pins to default the main board back to factory defaults then remove the jumper pin and leave off for first boot .When doing this be aware not to have the power cables connected to the server remove all power cords and the monitor . Prior to doing the first power up plug in the PS2 keyboard only then the monitor. Cross you fingers If you lucky your PS2 port’s will be working again if so shut down re install the jumper pin install the PS2 mouse.
Posted on Dec 04, 2009
W7 using dongle ps2 to usb
If you are trying to convert your Logitech Trackman Marble FX from PS2 to USB so it will work with Windows 7, you can't just convert the port type - you have to get an "adapter" that converts the PS2 signal to a USB signal. See for ATen - UC 100KMA. WEB SIte:
http://www.aten.com/products/KVM/KVM-Modules-&-Accessories/PS2-to-USB-Adapter~UC100KMA.html#.U5sYrCi4NAE.
It allows you to convert a PS2 keyboard and PS2 mouse/trackball with the one device. It's what I use and it works just fine. The regular $2.00 port adapter was useless.
They are on EBAY sometimes for $20 or so. GOOD LUCK. :)
Feb 14, 2014 | Logitech Trackman Marble FX Trackball
Toshiba aspire boots normally but moving the cursor or any key and the screen goes dark.
Try using a PS2 mouse and PS2 keyboard. It may be that your USB ports have lost their setup (assuming that you are using USB or wireless mouse and keyboard). If the PS2 hardware works fine, check that your USB ports are enabled in the BIOS, then check your device drivers in Windows to see that the USB hardware is recognized.
Oct 12, 2013 | Computers & Internet
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Nov 03, 2009 | Dell OptiPlex GX280 PC Desktop
My ps/2 mouse and keyboard are not working togather when plughed in togather but individually ther work fine
It is possible the ports are going bad, But both at the same time is strange. I don ot know if you know that PS2 is not hot swapable, Which means that you need to completely shut down the system before pluging them in. USB, the system can be on. If you keep having problems i would switch to usb mouse and keyboard,,,Darren
Oct 15, 2009 | HP Compaq d530 PC Desktop
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
Same problem...
get a new keyboard at walmart they are only about 12 dollars
Jul 02, 2009 | Logitech LX 300 Keyboard/Mouse
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
Trying to install windows and at the boot screen have my keyboard and mouse plugged in windows doesnt see it.. I tried the USB keyboard and nothing I just recently replaced the MOBO using anti-static wrist...
I have seen this before, and the best answer I can offer you is some Motherboards are better than others when working with usb devices while no OS is in place. I actually tried using usb / to / ps/2 adapters and it still would not recognize the usb keyboard in a couple of instances. I had to get a ps2 keyboard for the installation of windows. After windows was installed I hooked up the usb keyboard and it worked fine. (just speaking from my own personal experience here)
Sorry I do not have a more technical answer for you but I'm almost 99.9 % sure this should work, providing there is no problem with the ps2 keyboard port on the Motherboard. I have never failed to install windows unless there was another hardware based issue of some kind, but never a problem with a known good ps2 keyboard.
Just double check everything is seated properly and try to get into the bios setup, if you cannot use the usb keyboard for this, you can try the usb / ps2 adapter, but if that doesn't work either then use a regular ps2 keyboard. That should work fine, then after setup is complete, windows is installed, then your usb keyboard should work fine.
Mar 03, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Dell PowerEdge 1600SC Server Logo
420 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
