Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code 06F
My machine stops in the middle of the rinse and drain cycle displays f 6 and beeps, does not fully drain. how do i fix this?
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
417 44152400 21 code reads e63 and machine not draining properly
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Kenmore Front Load Washer
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Feb 20, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
My washing machine wont drain the water out before spin cycle it stops and turns off after wash so when you open the lid its still full of water
Hi just read your posting.Now you said in your posting it does not drain before the spin cycle, but does it drain before the rinse cycle?Does your machine stop and beep and show an error code in your LCD display or if you have the other model a series of lights?Have you tried advancing the cycle to spin and pushing the start button?Please reply with additional information and I can help you track down this fault.
Jun 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
Doesn't drain in rinse mode
Hi just read your posting.Now when it stalls in the rinse cycle does it start to beep and light up a couple of lights to indicate a fault code? Or do you have the LCD display model that shows the error code.If your machine shows some light on the same line of lights, there are 8 in a row , which ones are lit? Is it the 2nd and 4th or 1st and 6th--etc .Also if you have the LCD display model what is the error code?Please reply for further help.Hope this helped.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
