Question about HP G60-230US Notebook
Display colors are all wrong
Everything on my back ground has a red tint to it and is super grainy. The RGB balance is all where it should be though. This screen is oddly colored as well, a light blue is the background color. But words that have always been white, are still white.
  • Sarasvatas Kumar
    Sarasvatas Kumar May 11, 2010
    it might be hardware prob get it to local vendor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 132 Answers
This may have to do with your Windows Theme settings.
Step 1. Right click on your Desktop and click Properties
Step 2. Click on the Themes tab
Step 3. Select a different Theme (try the Classic Theme)
See if that solves your problem.
Posted on Apr 20, 2010
  • MyPC Solutions
    MyPC Solutions May 02, 2010
    Did my solution help solve your problem?
Have red tint in picture
It sounds like the color settings are out of whack, try going to the tv settings and reset them back to default. Then try changing the Red green blue values (RGB) in the color settings, simply lowering the red value might do the trick
Apr 10, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
When I take pictures now with my A85 the tint is green, my pictures have more of a green tint. is there a way of adjusting the color.
Sounds like the camera was adjusted for flourescent lighting. The PowerShot should have a menu with various Lighting scenarios such as natural, outdoor, nighttime, sepia, etc. I would check this first. It should be easy to find. If you can't adjust the color properly with these pre-set options, there may be an RGB adjuster although I doubt it. You can certainly use a photo editor on your computer easily as well to adjust the color balance easily. If you don't use Photoshop there are free online photo editors such as http://www.gimp.org. You want to look for Color Balance and an RGB slide bar, it is quite fun to play around with.
May 10, 2011 | Canon PowerShot A85 Digital Camera
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
A lot of green tint in the picture
Hi, what you do is unscrew and take off the grill, take off the black board behind it. You will see a little box for adjusting RGB you will adjust the screen rgb to get the tint to go away and have a perfect color then you will adjust the focus for sharpness. (reset the tv to factory settings before doing this so that your tint, color, brightness and everything else is in the middle.
Oct 17, 2008 | Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Insignia LCD tv 32".....
It's either the VGA cable you are using has a bad pin or the RGB/Color Scheme is set wrong. So try another VGA cable or try the LCDTV on another PC.
Feb 22, 2008 | Insignia LCDTV26 26 in. Television
Color
There's a known issue with this set due to defective rgb tubes...
See this forum:
http://www.hometheaterforum.com/htf/display-devices-tvs-projectors/105633-50-000-sony-
hdtvs-may-recalled.html
Dec 29, 2007 | Sony KP-57WS500 57" Rear Projection...
HP G60-230US Notebook Logo
248 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
