Question about AT&T Blackberry Curve 8300 Smartphone
The asterisk shows on the menu of my blackberry curve for my mailbox and my yahoo but when I click on it, it does not open up. I desperately need to retrieve my messages - please help!
    Brigadier General:
  • 7,752 Answers
This is what you need to do to correct this issue
pls make a backup of all your data and contacts...
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Posted on Jan 30, 2010
I cant open the messages in my yahoo mailbox
i cant get into my yahoo message
Aug 23, 2012 | Yahoo Mail
I need instructions on how to unlock this phone from verzion cmda not the one with a sim card
You must have blackberry curve 8520 unlock code for verizon network before you can unlock your blackberry. That code can be obtained from verizon or third party sites, both of them will take you some charge for a straight blackberry unlock code, but third party sites more cheaper and quick delivery times rather than network provider.
Jul 15, 2011 | RIM otion BlackBerry Curve 8520 Smartphone
Need free mep code for blackberry curve?
It's a clear and fully detailed guide on how to unlock a BlackBerry Curve :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Apr 07, 2010 | RIM BlackBerry Curve 8520 Smartphone
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do i unlock my blackberry curve 8520 smartphone
1. Turn on your Blackberry Curve 8520 phone with your current network/service provider’s SIM card.
2. Using the menu go to Settings Menu -> SIM card and press select.
3. While holding the SHIFT key, type mepd.
4. You should now see the five locking categories listed.
5. While holding the SHIFT KEY, type mep2.
6. Release the shift key.
7. You will now be prompted to enter the Network MEP code.
8. Enter the Unlock Code.
9. Enter Return/Enter.
10. Your Blackberry Curve 8520 phone should then be unlocked.
Now you should have yourself a fully unlocked Blackberry Curve 8520. Before you can use your newly unlocked phone on a new phone carrier’s network, you must buy a SIM card and order a voice plan with that carrier. If the steps above did not work on your Blackberry Curve 8520, do not try repeating as this could just permanently lock your mobile phone.
Jan 09, 2010 | RIM BlackBerry Curve 8520 Smartphone
I am using my daughter's old phone, a blackberry curve. She has customized it and I can't find the profiles icon. I need to get out of vibrate and put on a ringtone
The profile icon might be "hidden", if so, press the "menu" key on the BlackBerry then chose "Show all", this will show all the hidden icons.
If not, try to go to "options", then "profile". If that is not there...
Try to reset the BlackBerry by taking the battery out...
If that doesn't work then you need to reload the OS on the BB... (hopefuly you won't need to go this far)
Nov 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Permanently remove aim and yahoo off of my blackberry curve 8300
you can connect the phone using the usb cable to your pc/laptop , open the blackberry desktop manager and open the apploader then click on add/remove applications......untick the aim and yahoo appz then click finish and the program will remove them from your phone permantely
Sep 11, 2009 | AT&T Blackberry Curve 8300 Smartphone
Hi There, In the US, getting my yahoo email (using Mail program on a MacBookPro) (yes I have yahoo plus) works like a charm. But here in Canada, most of the time, the password gets rejected... what's give?
To set up access to a free Yahoo! Mail account in Mac OS X Mail:
* Install MacFreePOPs and make sure the freepopsd service is running.
* Select Mail | Preferences... from the menu in Mac OS X Mail.
* Go to the Accounts category.
* Click + at the bottom of the Accounts list.
* Type your name under Full Name:.
* Enter your full Yahoo! Mail address (e.g. "example@yahoo.com") under Email Address:.
* Type your Yahoo! Mail password under Password:.
* Make sure Automatically set up account is not checked.
* Click Continue.
* Make sure POP is selected under Account Type:.
* Enter "Yahoo! Mail" under Account Description:.
* Enter "localhost" (without the quotation marks) under Incoming Mail Server:.
o If you run into problems using "localhost", try "127.0.0.1".
* Type your full Yahoo! Mail address ("example@yahoo.com", for example) under User Name:.
o Mac OS X Mail probably has already entered your user name, and it's enough to append "@yahoo.com" to complete the address.
* Click Continue.
* Click Continue again, ignoring the error. We'll take care of that in a bit.
* Make sure Password is selected under Authentication:.
* Leave Use Secure Sockets Layer (SSL) unchecked.
* Click Continue.
* Select an existing mail server to send mail under Outgoing Mail Server:.
o You cannot send mail through MacFreePOPs. If you have no outgoing mail server through your ISP, you can use a Gmail or AIM Mail account's.
* Click Continue.
* Now click Create.
* Highlight the Yahoo! Mail account in the Accounts list.
* Go to the Advanced tab.
* Enter "2000" (not including the quotation marks) under Port:.
* Close the Accounts window.
* Click Save.
Access Free Yahoo! Mail with Mac OS X Mail Using IMAP Over IzyMail
To add a free Yahoo! Mail account in Mac OS X Mail using IzyMail, which provides access to all mail in all folders seamlessly:
* Make sure your Yahoo! Mail account is registered with IzyMail.
* Click + under the accounts list.
* Make sure IMAP is selected under Account Type:.
* Type "Yahoo! Mail (IzyMail)" under Account Description.
* Enter your name under Full Name:.
* Type your complete Yahoo! Mail address under Email Address:.
* Click Continue.
* Enter "in.izymail.com" (not including the quotation marks) under Incoming Mail Server:.
* Type your full Yahoo! Mail address under User Name:.
o If your Yahoo! Mail address is qwertui@yahoo.com, do type "qwertui@yahoo.com" (omitting the quotation marks).
o Mac OS X Mail probably has already entered the user name for you. If you already find "qwertui" in the User Name: field, just append "@yahoo.com".
* Enter your Yahoo! Mail password under Password:.
* Click Continue.
* Type "out.izymail.com" (without the quotation marks) under Outgoing Mail Server:.
* Make sure Use Authentication is checked.
* Enter your full Yahoo! Mail address under User Name:.
* Type your Yahoo! Mail password under Password: again.
* Click Continue.
* Click Continue again.
* Now click Done.
* Cloe the Accounts window.
* Click Save.
* Open the _Draft folder under Yahoo! Mail (IzyMail) in the folder list.
* Select Mailbox | Use This Mailbox For | Drafts from the menu.
* Open the _Sent folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Sent from the menu.
* Open the _Trash folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Trash from the menu.
* Open the _Bulk folder under Yahoo! Mail (IzyMail).
* Select Mailbox | Use This Mailbox For | Junk from the menu.
Done!
Aug 15, 2009 | Yahoo Mail
My calendar program is missing..
IN MENU--> SELECT BLACKBERRY LOGO BUTTON--> SELECT SHOW ALL.
1.To hide a Home screen icon, complete the following steps: Select an icon on the Home screen of the BlackBerry smartphone. Press the Menu key.
Click Hide Icon.
2.To show a hidden icon on the Home screen, complete the following steps:
Press the Menu key. Click Show All.
3.After the Show All option has been selected, to show a hidden icon, complete the following steps:
Select the transparent icon on the Home screen that you want to make visible.
Press the Menu key.Cancel the Hide Icon selection.
4.If not able to find Install Blackberry desktop Manager ...Take Backup.. reinstall the application from application loader in Blackberry Desktop Manager
Aug 12, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Email messages do not appear in inbox on Blackberry Storm
Dear Vbcarroll,
on your blackberry go in main menu- options- advance options- default services. if you have enterprise mail account setup with personal mail account, it can be the case that at the moment it is showing as desktop services but when you are in there click on main menu and change options to other mailbox which is in your case personal mail account.
that way in inbox you will receive both emails and you can see all together.
but as far as i know, I haven't setup personal account on my blackberry but i believe within main menu you get created another icon like mobile mailbox and where your personal mailbox emails are coming in. if option one doesn't work then please try to look for this new created icon within main menu.
update me if none of them are working or any other problem.
Thanks.
Regards,
AJoshi
Mar 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
43 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
