Did a system restore point and my touchpad dont work
I even redownloaded the drivers and it still didnt help...any sugestions?...
  • 395 Answers
If you did a restore and the problem still persist, then i'll advice that you run a thorough antivirus check. If this does not fix the problem then go ahead and format.
This should fix errors.
Kind Regards
Posted on Sep 24, 2009
Toshiba a215-s7437 touchpad will not work
Use a USB mouse for the meantime and try doing a system restore to a date when it was working fine before How to perform system restore (https://www.youtube.com/watch?v=oGXbMyFaROw)
If system restore did not resolve the issue then try uninstalling and reinstalling the driver for your touchpad.
You can go to toshiba website and download their latest touchpad drivers for your a215-s7437.
hope this helps.
Thank you
Sep 08, 2014 | Toshiba Satellite Computers & Internet
The touchpad cursor on my laptop suddenly freezes how to fix it.
REDOWNLOAD/REINSTALL THE TOUCHPAD DRIVERS SOMETIMES PEOPLE ACCIDENTLY DELETE SOMETHING IMPORTANT OR A FILE GETS MISPLACED OR THE COMPUTER MESSES UP SOMETIMES.... NOT SAYING ANY OF THESE ARE THE CASE BUT IT COULD BE.
Nov 21, 2012 | Computers & Internet
Help about my acer laptop touchpad,,,most of the time it didnt function,,,i dont know whats the problem,,my laptop is only 3 mants,,from the date i bougtht it,,,
Intermittent problem needs to analyze whether it is hardware or software? Hardware is contact resistance, must reinsert connector. Software is registry sequence, you can do a system restore back to a date which the touchpad works perfectly.
Feb 08, 2012 | Acer Computers & Internet
I have a sony vaio VGN-NR120E notepad. i cannot scroll with the touchpad. Please help.
Install the pointing device software.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR120E&upd_id=3049&os_id=28
Click the "Download Now" link and install it once it is done.
Hope this helps =)
Mar 02, 2011 | Sony VAIO VGN-NR120E/S Notebook
The scroll key on the touchpad in my hp compaq
locate the FN key and the touchpad key usually an F key(F1-F12) press and hold down the FN key and the touchpad key together, release the keys and check the touch pads.
Mar 25, 2010 | Compaq Presario CQ60-220US PC Laptop
I have recently bought an acer aspire 5532 and the mousepad has stopped working how can i check if it is enabled and re-enable it if it isn't
Hi
Thank you for your query
From what you are descrbing the mousepad has been locked up
Normally for Acer's the key to unlock is fn+F7 or F5 however if these 2 dont work the picture your looking for ontop of the F key is a small rectangle with a arrow/finger pointing to it
I hope this helps
Mar 04, 2010 | Acer Aspire 3050 Notebook
I have a dell insipron 1545, the mouse keys below the touchpad have stopped working in normal mode but will work in safe mode. I have Windows Vista
It seems to be a conflict with Touchpad drivers. For once, you can try a System Restore to resolve this issue. Else, you need to install the Dell touchpad drivers and application from the Dell support website to resolve this. You can download the drivers from the link after you select the correct Operating system version: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRON1545&os=WLH&osl=en&catid=&impid=. Save the file on desktop and right click on it, to Run as Administrator. Install the drivers and reboot your system. Now your Touchpad should work normally even in safemode.
Oct 23, 2009 | Dell F3534 Touchpad
Touchpad and buttons won't click on Sony Vaio
it could be caused because of hardware failure or software failure, in case of hard ware failure it would be best to call sony tech support but in case of software issue , if you remember the day it was working fine,
do a system restore to the date it was working fine, which will reset your software configuration to the date you know it was working ok, so if it was caused by software issue it will be resolved, but any programs that you installed after the restore date will be lost
to do system restore
reboot your system when you see the sony logo start tapping the F8 key and you will come to a menu here select safe mode and boot and then
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts select the bold date your system was working fine and continue as it guides,
If you think the information i gave you was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Sony VAIO VGN-CR420E/T Laptop
Touchpad Not Working
If you has been installed the right drivers, it is hardware problem.
Try to use the factory touchpad program for your sony touchpad and see what happen (not only the driver, also the program touchpad software)
Oct 06, 2008 | Computers & Internet
Toshiba Satellite Pro L10 - Touchpad and USB mouse not working
Do a system restore to a point date when your pad and mouse where working. If this does not work go to the manufacturers website and download the drivers for your notebooks keypad on another pc. Load them on a thumb drive and install them. You can limp navigate with the tab key. If restoring to an earlier date and reloading the drivers does not help back up all your critical files and reload your entire operating system. If it still does not work there is a hardware problem, but I highly doubt it. I hope this gets you going. If you need more help feel free to contact me.
George
Aug 03, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
