Question about Dell 3100cn Laser Printer
Dell 3100cn (color printer): color smudging - Dell 3100cn Laser Printer
  • 49 Answers
Smuding typically occurs when you print on a heavier paper without changing the settings. By changing the settings to a thick paper type, the page will be send through the printer more slowly. this will likely eliminate the smudging.
Cheers.
Posted on Mar 01, 2010
5 Suggested Answers
CowboysFanZ
  • 99 Answers
SOURCE: Dell 3100cn-smudge
The print toner cartridge has a small trap door that opens to let the toner adhere to the paper. Remove the toner cartridge and locate this moveable panel on it. This roller is VERY sensitive, and can scratch VERY easy. Use a soft LINT FREE cloth to GENTLY wipe the colored roller if you see any toner build up. If that does not clear up the problem you will need to replace your Fuser Unit which will need to be ordered from Dell or a 3rd party supplier. Its a pretty easy process, and instructions usually come with the fusers. If you have a printer warranty they will fix it for you. Thanks! //CowboysfanZ
Posted on Apr 24, 2008
  • 3 Answers
SOURCE: Dell 3100cn Smudges on all color except black
This is actually a drum issue, although changing drums doesn't always fix it. The problem is the at the tolerances between the transfer belt and the top cover of the drum is too close so the belt can scrape on the ribs inside the cover, getting a toner buildup and causing streaks in the color. Notice it is not streaking the black; this is because the black is laid on the belt last and the belt does not go around again.
This is such a flaky problem because a perfectly happy unit can suddenly start streaking because of temperature changes or, I suspect, even something as simple as moving the printer can cause things to move enough to cause the issue. A good article I have found for fixing it is at http://www.ahfx.net/weblog.php?article=133. Dell forums also discuss this issue -- it's a known issue and I think Dell should fix it.
Posted on Mar 30, 2009
  • 547 Answers
SOURCE: Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Posted on Jan 27, 2010
Testimonial: "Thanks! I have gone through all the instructions on Tech support for the printer. All cartridges have been cleaned and drum has been cleaned. Guess "
WonderTech
  • 268 Answers
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
Posted on Aug 04, 2010
How to stop my printer from smudging line on my paper
This often occurs when using aftermarket toner cartridges that are lacking sufficient developer. If you are not using a fresh genuine Dell cartridge, I suggest you try one.
Oct 06, 2014 | Dell Laser Printer 3100cn PCL6
Dell 3100cn printer prints individual colors fine. When printing full color picture the paper wraps around the fuser. Tried new fuser - same problem. Any suggestions?
Good old fuser wrap, what a pain. What type of paper are you printing on. Often with full page coverage printing I find that you need to user a heavier bond color printing paper to achieve any sort of good quality and reliability in feeding.
Mar 18, 2011 | Dell 3100cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
When I print color with my Dell 3100cn the color does not match what I see on the screen. I somehow need to make what prints match the monitor. HELP!
In general the color on the screen is never exactly the same as the printer. You will have to play with the colors on the screen and test the output to see if it is what you really want.
Jan 30, 2010 | Dell 3100cn Laser Printer
Manual for RAM upgrade
Memory Upgrade for Dell Color Laser Printer 3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Dell Color Laser Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed.
http://www.memorystock.com/memory/DellColorLaserPrinter3100cn.html
You should be able to get crucial or the likes to send you the correct memory - as for where it goes that will be in the manual
May 25, 2009 | Dell 3100cn Laser Printer
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Dell 3100cn-smudge
Apr 24, 2008 | Dell 3100cn Laser Printer
Dell 3100cn
I've the same problem with a 3000cn but on the black color. all other colors are great execpt the black one.
Any Ideas someone ?
Apr 02, 2008 | Dell 3100cn Laser Printer
Bleeding color
I have a similar problem. I just spoke with Dell support and they said that the problem is the printer drum. Fortunately, my printer is under warranty so they are sending me another.
Jan 23, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
370 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
