Question about Linksys Wireless-G WRT54GS Router (e125894)
After resetting the WRT54G2 router, the default password will not work and I cannot get access to the web based settings
  • 1,272 Answers
HI, Please note that by default the username for the router is blank and password is admin.
If that does not work then please reset the router for a longer duration and then try to login to its interface.
Hope this helps.
Posted on Sep 24, 2009
It has password and I can't open it
Resetting the Linksys Router to Factory Default
To reset the router to its default settings, press and hold the Reset button located at the back of the router for 10 seconds.
IMPORTANT: Older Linksys devices may require pressing and holding the Reset button for 30 seconds to complete the reset process.
kb19584-003_en.png To perform hard reset on your Linksys router, follow the steps below:
NOTE: The location of the Reset button may vary for every model.
If the normal reset does not work, unplug and re-plug the router's power adapter while pressing the Reset button.
You can also reset the router via its web-based setup page. Follow the steps below to learn how.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click the Administration tab then click on the Factory Defaults sub-tab.
kb19584-004_en.png NOTE: If the screen on your router's web-based setup page is different, click here.
Step 3:
Under the Factory Defaults section, click on the Restore Factory Defaults button.
kb19584-005_en.png The default settings of your router are now restored.
Sep 20, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
Forget user name and password for a wrt54g2
You need to reset the Wireless Router to change theuser id and the password. The factory default reset button (red) is on the back side. Before reset connect your work station or laptop to the router. Press the reset button for few seconds, it should reset the unit. To access the router through the laptop/workstation, open the IE put this IP address 192.168.1.1 in the address bar of IE. You will see the window pop up for user and password, Leave the user fileld blank and in the password filed put "admin" . After this you can change all the setting.
WARNING: when you reset your router all the connection detail will be set to default, you need to have this information or call your service provider to help out.
For reference use this link: http://homedownloads.cisco.com/downloads/userguide/1224642019596/WRT54G2_V15_UG_NC-WEB.pdf
Add a comment
Sep 01, 2011 | Linksys WRT54G2 Wireless Router
Need security key for linksys router
If it is your router your trying to access try these https (only necessary to try second one if first doesn't work)
these are the network/password config for linksys
http://192.168.1.1
http://192.168.0.1
May 06, 2011 | Linksys WRT54G2 Wireless Router
I cannot access my WEP Hex Key, how can I locate it or reset it?
Connect to the router with an ethernet cable. Use a web browser and connect to 192.168.1.1 You should see a router home page. login as admin (default id= none/blank/null password=admin) These detailed instructions may help here http://nabtron.com/forgot-linksys-wrt54gr-password-how-to-reset-settings-of-the-router/180/ browse to the wireless/wireless security section and set up your WEP key. You can preview the web page layout here; http://ui.linksys.com/files/WRT54G2/ e.g. http://ui.linksys.com/files/WRT54G2/1.0.00/WSecurity.htm for you this would be http://192.168.1.1/WSecurity.htm
Jan 08, 2011 | Linksys WRT54G2 Wireless Router
User name and password -does not accept anything I put in on Linksys router page
Option 1
Press the Reset Button on your bridge for approximately ten seconds and then release it.
Option 2
Restore the defaults from the Password tab in the Bridge's Web-Based Utility.
The following steps will guide user on how to reset the bridge based on Option 2.
Step 1:
Double click the Internet Explorer web browser on your Desktop.
Step 2:
Type the Music Bridge's default IP address, 192.168.1.210 in the Address field. Then press Enter.
Step 3:
A password request page will appear. Use the default password admin and click OK.
NOTE: You can set a new password later at the Password tab.
Step 4:
This is the default page you will see in the Bridge's Web-Based Utility. Click the Password tab.
Step 5:
At the Password tab, click the Restore Factory Default button and click Apply to save the changes.
NOTE: Resetting the Music Bridge will erase all of your settings and replace them with the factory defaults. Do not reset the Bridge if you want to retain these settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | Linksys WRT54G2 Wireless Router
Cannot remember log in info
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
Forgot user name and password
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Group LIWRT160N Ultra RangePlus Wireless-N Broadband Router say's password is not enough characters, however I am using the right password. Why can't I set up this Window's computer?
Okay,i only option is to reset the router to its factory settings.
Please follow the steps to reset the router.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router’s web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router’s IP address will become “192.168.1.1,” the username is still blank, and the password will be “admin.”
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
Step 1:
Access the router’s web-based setup page. .
NOTE: If you are using Mac to access the router’s web-based setup page,
Step 2:
When the router’s web-based setup page appears, click Administration then Factory Defaults.
Step 3:
Look for Restore Factory Defaults and select Yes.
Step 4:
May 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
I am trying to install an HP 7460 wireless printer to my HP cpu via a linksys router. My password for the router is 7 letters, and the printer says it has to be 8 letters. How do I change the router...
When accessing the router’s web-based setup page, a log-in screen will appear asking for the router’s password. The router’s default password is “admin.” You should change the password for security purposes.
The router’s password must be changed to:
  • Prevent unwanted users from accessing the router’s web-based setup page.
  • Enable Remote Management.
The router’s IP password can be changed by:
  • Running the router’s setup CD.
  • Changing it on the router’s web-based setup page. For instructions, please follow the steps below.
Changing the Router’s Password
Step 1:
NOTE: If you are using Mac to access the router's web-based setup page.
Step 2:
When the router’s web-based setup page appears, click Administration.
Step 3:
Enter the new password on the Password and Re-enter to confirm fields.
Sep 26, 2008 | Office Equipment & Supplies
Linksys Wireless-G WRT54GS Router (e125894) Logo
119 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
