Question about Cisco IOS
WHAT IS SDM - Cisco IOS
  • 177 Answers
Pass. floor panel flooded, SRS module damaged. Purchased air bags, clock spring, harness and module from undamaged Impala.
You can't just replace parts like that .
DTC B1001 Option Configuration Error
When the ignition is turned ON, the inflatable restraint sensing and diagnostic module (SDM) compares the restraints ID that is stored in the SDM to the restraints ID that is stored in the body control module (BCM). The restraints ID that is being compared contains the last four digits of the SDM part number. Then, the SDM compares the VIN that is stored in the SDM to the VIN that is stored in the BCM. For more detailed information concerning the class 2 data lines, refer to Data Link Communications Description and Operation in Computer/Integrating Systems.
If the SDM is replaced you must setup the new SDM part number in the BCM. With a scan tool, select the SIR module setup. Select Setup SDM Part Number in BCM and follow the on-screen instructions. After, you must setup the new SDM. Select Setup New SDM and follow the on-screen instructions.
Oct 13, 2016 | Cars & Trucks
Reset airbag light
Hey Earl, what's going on ? The air bag module is usually under the passenger seat or the center console ! The only way to turn off the light is with a up grade scan tool , not code reader. An the light is on for a reason , problem with the system ! If you don't know about this don't mess with it , you could deploy an air bag !
The AIR BAG indicator, located on the instrument panel cluster (IPC) is used to notify the driver of SIR system malfunctions and to verify that the SDM is communicating with the IPC. When the ignition is turned ON, the SDM is supplied with ignition 1 voltage and requests the IPC to flash the AIR BAG indicator 7 times. While flashing the indicator, the SDM conducts test on all SIR system components and circuits. If no malfunctions are detected the SDM will communicate with the IPC through the class 2 serial data circuit and request the IPC to turn the AIR BAG indicator OFF. The SDM provides continuous monitoring of the air bag circuits by conducting a sequence of checks. If a malfunction is detected the SDM will store a diagnostic trouble code (DTC) and request the IPC to turn the AIR BAG indicator ON. The presence of a SIR system malfunction could result in non-deployment of the air bags. The AIR BAG indicator will remain ON until the malfunction has been repaired.
Feb 06, 2015 | 2005 Chevrolet Tahoe
What does error codes: B0100 and B0140 indicate wrong on a 2011 Buick LaCrosse CXL 3.6 V6 eng.?
B0100:
Perform trouble checking for the following: the front end sensor, the SDM module, the SDM wiring harness connector. Damage to the following parts needs replacement or repair. For the DTC B0100, detach the front end sensor1 connector and also detach the SDM connector. Perform trouble checking of the signal and voltage circuits between the SDM and the front end sensor for a short to voltage and for a short to ground. Reconnect all the SIR components and if the DTC B0100 is present then the front end sensor1 has to be changed.
B0104
Perform trouble checking for the following: the front end sensor, the SDM module, the SDM wiring harness connector. Damage to the following parts needs replacement or repair. For the DTC B0104, detach the front end sensor1 connector and also detach the SDM connector. Perform trouble checking of the signal and voltage circuits between the SDM and the front end sensor for a short to voltage and for a short to ground. Reconnect all the SIR components and if the DTC B0104 is present then the front end sensor2/right has to be changed.
i could not find anything on the B0140 code so i included the B0104 incase of typo
May 18, 2014 | 2011 Buick LaCrosse CXL
Where is 2002 gmc envoy airbag module located???
There is a module that controls the air bags called the SDM Sensing and Diagnostic Module, but the air bags themselves are called modules. If they are referring to the SDM...
(1) Lower Console
(2) Inflatable Restraint Sensing and Diagnostic Module (SDM)
Hope this helps (remember to rating this free answer and leave a testimonial comment). Thank you for using Fixya.
Oct 13, 2011 | 2002 GMC Envoy
No input signal, go to power save sony sdm-hs93
I f you see the message on the screen indicating 'NO INPUR SIGNAL', you need to check the VGA cable and both ends of the connectors also. Try this monitor with other PC also.
This SDM-HS73/93 have common problem: bad backlight assemblies due to poor workmanship in sodlering works, see my pictures below. You should also inspect the caps. This is not recommend for DIY.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS93/
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
Apr 18, 2010 | Sony SDM HS93 19" LCD Monitor
ACT/SDM 9350 MULTIPLEXOR
I have 1 ;)
a netperformer SDM-9350
I realy dont know its specs but you can contact me at glenns@aapt.net.au
Jun 17, 2008 | Gateway ACT Refurbished LUCENT...
Computers & Internet Logo
24 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
