Question about Kodak EasyShare Z740 Digital Camera
Viewfinder fades out in sunny conditions and also I have the auto shutoff set for 10 minutes and it turns off in one minute.
    Brigadier General:
  • 11,967 Answers
All screens are hard to see in sunny conditions. Is the screen shutting off in one minute or is the camera shutting down in one minute? Does pressing the shutter button half-way turn it back on?
Posted on Sep 24, 2009
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
My dolphin inexplicably shuts off for no apparent reason. It's been happening since I charged it last - about 4 uses ago. It'll be playing for 5 to 10 minutes, even 15, then just shuts down. ...
Have you checked the settings? There's one in there for auto-shutoff. I had this happen and it turned out I had accidentally changed this setting.
Sep 12, 2011 | NuTech NU Dolphin (4 GB) MP3 Player
Large green wavy lines faded in background for 2 months. Then once turn on slowly fades to solid green. Turn off for 10 minutes turn back on, good picture for 3-15 minutes, then fades to solid green....
The Green CRT has shorted and will need replacement. You can verify the problem by removing the Green CRT drive board from the green CRT dont unplug the wires just slide the board off and let it hang suspended then try powering up the set if it stays on without shutting down then you will no its the green CRT for sure. You can get a green CRT from www.tvrepairworld.com
Jun 19, 2011 | Sony KP-57WS500 57" Rear Projection...
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Can the Intermatic El210 be set to turn things on and off?
You will need a more sophisticated timer than most hardware stores carry. Go to Smarthome.com and click their timers and automation section. There you will find many levels of sophistication in timers. good luck
Jan 25, 2009 | Intermatic EI210 Electronic Auto Shutoff...
Ei210 in wall countdown timer in undocumented ''test mode''?
You could try disconnecting power to the switch for a few minutes maybe that will reset it. Other than that I would say cut your losses and replace it. Hope this helps a little.
Nov 12, 2008 | Intermatic EI210 Electronic Auto Shutoff...
Auto shutoff
Go to "Settings" -> "Auto Shut-Off" - there i set a time like 5 or 10 minutes, and press the "enter"
The auto shut off is if the device is left idle for that amount of time.
It does not function as a sleep timer, per say.
I hope this helps
Please rate accordingly
Thank you
Computerrep
Jun 16, 2008 | SanDisk Sansa m240 MP3 Player
Kodak EasyShare Z740 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
