Question about IBM ThinkPad T23 2647 Notebook
Hard drive crashed and burned and have replaced the hard drive, revised my boot order in the bios setting but cannot get a boot from the XP CD. Continue to get the PXE E61 and PXE M0F error no OS found.
  • 1,272 Answers
Hi Bill,
Try this:
Turn on the laptop and start pressing f12 key.. it will show you the boot menu, select your CD/DVD drive and press enter. If it still does not boot then please try with another bootable CD as the CD might not be working.
Let me know if you need any further help.
Regards
Anand
Posted on Sep 24, 2009
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
I am trying to install xp on a clean disk but when i try to boot to cd i get ntldr is missing..how do i fix this? bios are set to default
Go into the bios and set the boot order to CD drive first and HARD DRIVE second.Setting the bios to defaults often doesn't set the boot order right to install an operating system
May 06, 2010 | Gateway 450ROG Notebook
Dell Optiplex GX270 will not boot from disk
Does it show
boot from cdrom?
did you answer (Y)
then hit spacebar?
have the bios set to boot from cdrom/first boot device cd-rom?
If any of these settings are not applyed you will not restore xp on your computer
go into bios and conferm settings
first boot device if set as floppy or hard drive change to cdrom
on some systems you can hit the (f12) key to bring up a boot window and select the cdrom and boot from there then it will ask the normal questions
Dec 03, 2009 | Dell Optiplex GX270
Describe your How to solve my Hard disk bad sector Problem
Easy solution would be to format and reinstall your operating system this will mark bad sectors and prevent your system from using those sectors... or follow the sets below if you really want to attempt to fix them
If you are familiar with burning images you can download the Hiren Boot CD image, burn it to a CD and then boot from it.
How to Burn image files http://pcsupport.about.com/od/toolsofthetrade/ht/burnisofile.htm
Hiren Boot CD download http://www.hirensbootcd.net/
Once you have your Hiren CD Insert into your computer and boot from it If the CD did not boot make sure your Boot order in BIOS is set to CD/DVD as the first boot device Generally you press Del F1 F2 or F10 to enter BIOS when the comes first starts to boot Look for Boot Priority or something similar to that and set CD/DVD as 1st device
Ok once in the Hiren CD menu (text menu) goto Hard Drive Tools followed by HDD regenerator This process can takes days and may or may not work
Please comment if you need further clarification or assistance
Thank You
Nov 21, 2009 | Samsung (SP0411N) 40 GB Hard Drive
I have a gateway cx210x laptop i got from a friend her hard drive crashed i formated the hard drive and ran scandisk on it it came back with no problems. She didnt have the original disk for it so i...
Hi
The ISO files need to be burned into a cd with a special program. Please use this software. http://www.ntfs.com/iso-burning.htm
Next, the reason why you are getting the error message is because the computer is not starting from the cd, or the cd was burned incorrectly.
The computer is most likely starting from the hard drive instead and since it's formatted you get the error message.
To get the computer to start from the cd instead and to install the system again, you need to adjust the boot order.
The laptop might have a Boot menu feature (look at the screen right when you power it on and see if it says anywhere press xx key to enter Boot menu) If you don't have the boot menu option then you need to enter setup or bios, same thing different name.
The computer will say at some part of the screen to press xx button to enter setup or bios / cmos.
In Bios you must adjust the boot order so that the Cd / dvd drive is before the hard drive in the order. this way the computer will start from the cd instead of trying the hard drive.
Here are a few good tutorial videos on the subject of changing the boot order.
How to Install Windows Part 1 of 2
boot order at middle and towards end of video.
Change Boot Order and Boot from a CD/DVD
Let me know if the problem is not solved or if you need further assistance.
Thank you,
Ekse
May 06, 2009 | Computers & Internet
Boot windowsxp from USB drive not from Cd/Dvd drive
Your BIOS would need to support booting from USB. If it does then you would see the option 'Boot from USB' in the section of your BIOS where you select the boot order. Select the Boot from USB option then set the USB drive to 1st boot device.
Apr 29, 2009 | Samsung SpinPoint SV1604E 160GB U133...
Booting Notebook using external devices.
This should do it for you.
On the Phoenix BIOS:
Go to "Advanced BIOS Features".
Go to the "1st Boot device" and set it to "USB-ZIP".
(Phoenix BIOS, Revision 6. you need to go to the Boot Order screen and select "Harddisk" and hit enter, giving you a list of IDE hard drives this BIOS prefers to call a USB device an IDE harddrive)
Jan 09, 2009 | Toshiba Satellite P15-S420 Notebook
Hello i have installed AVG anti virus n it makes my pc system crash!!!!!!! Just i tried to format my pc but failed it says missing operating system and no longer boot. I assured my BIOS and set Boot CD but...
It sounds like your pc is trying to boot from the formatted hard drive. Go into your BIOS and make sure both the hard drive and CD drive are detected. Make sure your CD drive is set as the first boot drive and disable all other drives for booting.
Nov 30, 2008 | Computers & Internet
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
IBM ThinkPad T23 2647 Notebook Logo
41 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
