Question about Frigidaire ATF6000ES Front Load Washer
Door replacement we have a frigidaire front load washer with glass window and we had a little accident and broke the glass can we find a replacement???
    Sergeant:
    Champion:
  • 262 Answers
Yes go to frigidaire .com and you can get it there or repair clinic.com
Posted on Dec 18, 2007
The door on my fridgidaire atf8000fs1 sags so it doesn't shut correctly. I've had to order a new door striker since the last one broke off. How do I adjust it so it hangs correctly?
Frigidaire washer door sagging so strike and door lock not lining up correctly. After a period of time front load washer doors tend to start to drop below normal position. The glass in the front doors are very thick, heavy and only supported by plastic inner frame. This combined with continued opening and closing will over time make your front load door start to sage. Fortunately Frigidaire makes a door shim kit for this problem.
After you have ordered and received the shim kit part #137309800. Start with removing the three screws holding the door to the machine. Lay the door face down on a soft surface as to no scratch the front of the door and glass. Remove the screws securing the outer frame and with a very small flat screw driver shim it between the inner and outer panels. Make sure to note the position of the frame and glass. Next remove the inner plastic frame, you should have access to the hinge at this point. Install the shim kit according to the instructions that come with the kit. Reinstall the hinge, inner frame and screws. Install the door back onto the washer, your door strike and lock should line up in the correct position at this time.
i got this answer at http://www.appliancerepairquestion.com/2013/04/frigidaire-atf8000fs1-washer-door-not.html
Jun 19, 2011 | Frigidaire Affinity ATF8000FS
Our frigidaire 10 year old front-load washer is vibrating way too much. it knocks on fast spin. is something broke?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 12, 2011 | Frigidaire Washing Machines
FRIGIDAIRE WASHER GLTF2940FS / WASHER HAS POWER BUT WON'T START/ IT DISPLAYS LOC IN THE ESTIMATED TIME WINDOW
means display is locked look for little lock symbol on panel,
press and hold key for 5 seconds
Sep 01, 2010 | Frigidaire GLTF2940F Front Load Washer
The door lock on my frigidaire washer
The locking mec is jambed or broke easy fix hope this helps
Apr 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Is it possible to replace glass on front of washing machine?
yes it is but it is alot of work plus it cost about 100.00 for the glass in the door
Jun 06, 2009 | Frigidaire ATF6000ES Front Load Washer
The glass broke during spin
metal objects in wash? replace glass
Mar 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Glass top broken
All you can do is to have it replaced.
Most housemold insurance covers for this sort of accident.
Dec 14, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire ATF6000ES Front Load Washer Logo
121 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
