Question about HP Laserjet M2727nf Multifunction Printer
Th edisplay is off
My M2727 printer does not start normally. Sometimes the display is off as well as all the leds, some other times it only displays HP and the 2 segments of the arrow and then stops.
How to solve this problem?
  • 223 Answers
This is known as a formatter failure
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If you are within a 2 year period of the original purchase date contact hp in order for them to create a case under a service note for the formatter failure and so that you can contact an authorized support provider and have the printer serviced.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
My HP LaserJet 2420n Printer is starting but I am not getting the LCD display and LEDs are not getting on and printouts are not coming.
If the printer is printing normally, problem with Display check display connectors,replace it,,,,, if printer is not recognising by system replace formatter assm..
Sep 15, 2011 | HP LaserJet 2420 Printer
I have a IBM 9068 Model S01,it is sometimes showing error code 18.If I tilt up the printer assembly during the printer power on it is ok.If I tilt down the printer assembly meaning to it's original...
Error 18 is a "Paper Edge Search Error".
1. Check document for damage and check it meets specs.
2. Check that Ribbon Cartridge is installed correctly.
3. Do "Form-Edge Sensor Service Check"
4. Do "Platen" adjustment.
Sensor Status Display:
. Start Self-Test (press and hold Start 1 on panel: then turn on printer. Keep holding button until at least "00" is displayed.
2. Use a magnet to override cover closed/open sensor to the left of the Start1 button in the indent.
3. Press Reject Off button until "4" is displayed.
4. Press Start1 button to shift to next digit.
5. Press Reject Off to display "4"
6. Display should now read "44"
7. Press Start2 button. The LED display indicates sensor status'
8. You will see changes with inserting paper or removing paper.
FORM-EDGE SERVICE CHECK:
Perform sensor status display as stated above. The sensor is located on the print head carriage on the left side.
1. The upper right vertical segment of the left LED digit is assigned to the form-edge sensor for Command "44"
With no paper the LED segment is unlit.
2. Check the sensor by inserting paper. Move the print carrier to the right to access the sensor mounted on the print carrier.
If the LED segment becomes lit when you insert the paper, and becomes unlit when you remove the paper, sensor is OK.
3. If the sensor does not work, check that the sensor cable is connected correctly. If the cable is okay, replace the following one at a time:
a. Form Edge Sensor -46H2648
b. Form Edge Sensor Cable -46H2730
c. Main Card -
1.46H2632 - Serial Interface
2.46H2634 - Parallel Interface
PLATEN ADJUSTMENT:
Mar 28, 2011 | IBM Office Equipment & Supplies
M2727 will not initialize.
You have to be a little bit more specific next time, we have 2 possible scenarios:
A) The printer freezes at the HP LOGO
B) Blank display / No display
Both are usualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M2727 will be extended 1 extra year (means you have 2 years coverage) if the printer has one of the issues listed above I Hope this can help You can contact me directly on : eliteprintersolutions@hp.com
Jun 01, 2010 | HP Laserjet M2727nf Multifunction Printer
THE FRONT PANEL DISPLAY IS BLANK. HAVE I DONE
Perhaps, the manual mentions a Dimmer setting under the Display Set Menu but doesn't specify how dark it can get. Give it a try.
Dec 26, 2009 | Yamaha RX-V1000 Receiver
Low heat error
the fuser lamp is likely blown, if you turn it on and leave it for a few minutes and then feel the back access door and it is cold you will need a new fuser lamp
Nov 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No display on hp laser
Does the printer otherwise print? If so, then the panel is dead.
Aug 20, 2009 | HP M2727NF Laserjet Printer
M2727 MFP no lights on the display
probably a cable is loose or not connected for display. printer could be faulty or you mught fix easily.
COMPAQ PRESARIO DESKTOP PC SR1215IL. When switched on, cpu boots normal but no display on monitor. instead a sharp and bright blue vertical line appears for few seconds on the middle of screen. led of the...
tricky!! oh hi im Dyanne.. a totally unresponsive black screen can be th result of failure of th LCD or LCD inverter.( a specialized piece of electronics that energize th screen) to rule out th failure of th video display adapter or circuitry, try plugging in an external monitor..a standard pc monitor.. attached direct to th lappy. if it works, (as i susopect) th motherboard and video display are both working ok and its th LCD which is at fault. this can sometimes be repaired by a competent specialist. good luck xx
Dec 25, 2008 | Compaq Evo D300 PC Desktop
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
HP Laserjet M2727nf Multifunction Printer Logo
316 people viewed this question
Seeker5211
Seeker5211
