Question about Sony DCR-HC21E Mini DV Digital Camcorder
When I switch on my DCR-HC21E Mini DV there's nothing on the LCD. Just blank. No lights nothing. So I can't use the touch screen menu. Can I fix it myslef ?
  • 10,594 Answers
Do you hear start up (ding) soundin camcorder? does it eject tape?
If yes, then flexible connecting wire between lcd board and camcorder board is cracked/ broken and need to be replaced.
If you can apart camcorder and have little experience in electronics stuff repair, I can provide you part number of that flexible wire info.
Posted on Sep 24, 2009
Hi, I have a Sony DCR-HC21E the LCD won't turned ON? What is the possible problem on this matter?
It could be your battery or battery charger, This units are very touchy about electrical surges & changes of temperatures.
Aug 19, 2010 | Sony DCR-HC21E Mini DV Digital Camcorder
Tip
LCD Side Screen Display Not Displaying
I managed to strip the digicam and found the MAIN FEED RIBBON CABLE DAMAGED du to normal open & close and turning of the sidescreen.
Replaced ribbon cable. PROBLEM SOLVED.
Hope this may help.
Aslam
on Feb 13, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
Buttons on touch panel of my DCR-HC21e Sony Handycam stopped working.
This fault is often caused by a failing flat cable that connects the LCD panel and the rest of the camera. In its early stages it is possible to get the buttons on the touch panel to work by carefuly changing the angle of the LCD panel while trying out the buttons until you get a position where they work.
When the flat cable gets worse , the picture on the LCD panel will start deteriorating and go off altogether.
At this stage you may consider having the flat cable replaced.
Oct 01, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
My Sony Hc42 camera LCD, view finder gone blank
cheak ur lcd srip and there is a samll switch that chaing over switch cheak it
Jul 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
"Lens cover not open" message
There is a switch sensor which will detect if the switch is open. Try switching rapidly a couple of times, as dust must be lodged.
Mar 25, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
LCD Screen Turns Blank with i rotate it 180 degress
Seems like the cable is damaged. You should get it fixed by SONY.
Feb 24, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
The problem is a bad CCD inside the camera. I Sony was providing free service for some of their other models but failed to provide service (recall) on these models. contact Sony at 1-866-703-7669
Feb 07, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
How to connect dv camcorder to pc?
Hello, please check this link: http://support.sony-europe.com/dime/camcorders/DV/DV.aspx?l=en&m=DCR-HC21E If you need more info please advice. Arpi
Jul 13, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
LCD Blank
the flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
May 02, 2007 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony DCR-HC21E Mini DV Digital Camcorder Logo
119 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
