Question about Linksys Wireless-G Broadband Router
How can i install my wireless router without the installation cd?
    Problem Solver:
  • 19 Answers
Linksys routers have a web interface. plug the router in, use a network patch cord to connect the PC to the router. (don't put it in the Internet port) pick the 1 of 4/8 other ports depending on the router. the router should hand out an IP address. get to a command prompt (XP click on start then run then type cmd) VISTA in the search area type cmd
This will get you a command prompt. at the prompt type ipconfig
you should get something that reads like:
IP ADDRESS 192.168.0.2
SUBNET MASK 255.255.255.0
GATEWAY 192.168.0.1
The numbers may not match, but the key is to write down the gateway number. the "."'s are important. So write down the number as displayed. Type the word EXIT to close the command prompt window.
Then open Internet explorer (or which ever browser you are using and type in the address line http://192.168.0.1 (if that isn't the gateway number replace the numbers with what displays as the gateway. This will bring up the Web interface for the router. Linksys user name and passord defaults are admin and admin.
If that doesn't work, then the router has been previosly configured, and you'll need to reset it. to do so, there is a little reset button on the back.use a pencil or a non conductive object to press the button in. hold it un and watch the lights on the front, they will all light up, and the power light will blink. when that happens, release the button. Then unplug the power to reset the device, and plug it back in. Follow the steps at the beginning of this solution, and you should be good to go.
Posted on Sep 24, 2009
    Problem Solver:
  • 14 Answers
I believe you are using a Linksys router.
You can install it manually but there are things that you need to consider.
1. Your dsl provider. Because some modems like if your modem came from AT&T (Bellsouth) the modem needs to be set to a bridge mode.
Note: You can check with the tech support of your dsl provider if this has to be done.
2. If you are using a PPPoE connection on the modem. Meaning you know your UN and Password. Here is a document on the internet that you can check on. It has a step by step process on how to install the router manually.
http://www.betterbuilt.com/docs/ppoe_setup_07252005.pdf
The steps are to long that is why I gave you the link. And so that you can save it to your computer or print it out for you to have a copy.
4 Suggested Answers
  • 3 Answers
SOURCE: install 2wire 1701hg without installation CD
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Posted on Feb 07, 2009
  • 33 Answers
SOURCE: how do i install the router onto my pc without the install cd?
Start, Run, type cmd and enter. Type ipconfig and enter. If you have the ethernet cords plugged into the correct ports you will get a gateway ip address which you will type into your browser address bar and then you should be able to manually configure your router given your connection and service type. Hope this helps
Posted on May 20, 2009
govinda123
  • 2263 Answers
SOURCE: lost installation cd for belkin F5D7234-4 G
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Posted on Feb 01, 2010
How to install a wireless router without installation CD
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 11, 2012 | Linksys Computers & Internet
Nstallation cd is missing for DIR-600...Hello, If you don't have the installation disc anymore, you can...
open the setup page of the router and change the settings manually.
Like other routers, you can install wireless router without installation CD also,
Read how to setup router without installation CD
Jul 04, 2012 | D-Link DIR-600 Router
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
No cd to help install router
ya without ch u can install
open ur browser type 192.168.0.1 means do in manual way by click on router icon in my network place
Jun 26, 2010 | Belkin (F5D7230-4) Router (587009)
Lost my linskys wireless-g wrt54gs cd installer
you can setup the router manually without the CD.
1> plug a network cable into the router, and your computer
2> type the following into your web browser http://192.168.1.1
3> enter your settings for your ISP
4> choose your wireless settings (it is recomended to setup some security on your network so people can't have access to your network without authorization)
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Lost wireless router CD
You can make the router working even without using the CD. Who is your ISP? Are you having concern with wired or wireless connection?
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
Install 2wire 1701hg without installation CD
Nov 04, 2008 | 2wire (1000-400108-001) Router
The cd wont work that i got with the wireless router
Yes you can install it without a CD you just need to call the Linksys tech support number and a tech will walk you through in manually configuring the router without the use of setup CD dial this number its free 1800-3267114 and yes your WII will work fine with it Lnksys will also be able to help you with that concern..
Hope that helps..............
Aug 06, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
140 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
