Question about Apple iPhone 3G
My sim card slot is broken how do u open it ?
    Problem Solver:
  • 7 Answers
Take a paper clip and push in side the little hole next to the sim card slot. The card will pop out.
Posted on Sep 24, 2009
2 Suggested Answers
SOURCE: Inserting my sim card.
there is no sim cards on verizon. use some common sense man
Posted on May 22, 2008
Sim card for Samsung Galaxy tablet 4?
A SIM card is for 4G LTE internet service, so if you have a Samsung Tab 4 ensure it is 4G capable before trying to insert a SIM card. If you try to insert a SIM card into a SD Card slot you may damage the card reader.
That being said, I believe it is located on the right side of the tablet. Sometimes the SD Card slot and the Sim card slot are right next to each other. Once you open the cover that reveals the slots there should be small icons for the SD Card and the Sim card. Normally, the SIM card slot will have a little notch on the icon. Attached are guides with pictures.
http://www.samsung.com/us/support/answer/ANS00030415
SIM card Samsung Galaxy Tab 4
Oct 22, 2016 | Samsung Tablets & eReaders
I have lenovo ideapad a10 where do I insert the sim card I see no slot for it
To Install the SIM card:
1)Open the device back cover from the bottom left in direction of the arrow, insert the SIM card to the correct card slot
To remove the SIM card:
1)Open the device back cover from the bottom left in direction of the arrow, press and hold the front of the SIM card, and flip it out slightly.
How to install and remove the SIM card Lenovo A10 70 Tablet Lenovo Support...
Dec 21, 2015 | Lenovo Computers & Internet
Sim card slot is broken
you have to go to a service center and change it! no other way......
Jun 23, 2013 | Cell Phones
IPhone 4s is coming up with invalid sim or no service
I just had the same problem. I used a paperclip to open and remove the sim card tray. I blew on the card and the opening to clear off any dust. After re-inserting the card, the device said "No SIM" for a moment then registered and regained service. I hope it helps!10_22_2013_4_27_57_pm.jpg
Oct 31, 2011 | Cell Phones
Insert correct sim
first you need to open the back case of that phone.....,,then after opening the back case...remove the bateery from its position..then find where is the sim slot takes place after that put now the sim card to its proper way...the proper way in slotting the sim is place on the top of the card slot...
May 16, 2011 | Sony Ericsson M600i Cellular Phone
I can't get a sim card to work in my sciphone i9+++ I've tried putting it in both sim card slots, and I've tried sim cards on different networks, I can't get it to work.
maybe you didnt put it on the corect slot or you need to go to settings and it tells you what sim slot do you want to use for your sciphone i9+++ because i have one.
Nov 20, 2009 | Dual Electronics N99i Cellular Phone
Emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
Jun 02, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How to change the simcard of my apple 3g iphone?
The SIM card in the iPhone is removable, but it's hidden. To remove the SIM card, you need a paper clip.
We are checking to see if this voids your iPhone warranty. If you are concerned that it might, please don't perform this task.
The iPhone's SIM card is located behind this door.
1. Locate the SIM Card Slot
The slot is located at the top of the iPhone, between the headphone jack and the power button.
The paper clip is a valuable tech tool.
2. Open the Slot
Take your paper clip and insert it into the little hole. Then firmly push down until the slot pops up.
3. Remove the SIM Card
The SIM card is in a cradle. You can pop the card out of the cradle.
To replace the SIM card, put the card back in the cradle. The cradle and card are notched in a way that forces you to replace the card on the proper side. Then just slide the card back into the iPhone.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Apple iPhone 3G
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Apple iPhone 3G Logo
    1,347 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
