Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Replace belt on dirt devil vision - Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
SOURCE: the belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Posted on Jan 13, 2009
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
Posted on Jan 15, 2009
galati2k
  • 281 Answers
SOURCE: Dirt Devil Vision bagless not working
make sure your brush roller is turning.unplug the vacuum and see if you can turn the brush roller by hand.if it turns real freely then your belt is more than likely broke
Posted on Apr 09, 2009
SOURCE: i don't know how to
Take all the screws off the bottom to access the beater bar than slide out (belt will also be right there ) just slide a new one on......
Posted on Nov 12, 2009
SOURCE: dirt devil en vision
Locate model no. at the rear bottom of the vacuum.
Then go to Dirt Devil site: http://www.dirtdevil.com/CustomerService/Manuals/
(this site will not find the manual under the name, just model #).
Posted on Nov 18, 2009
Brush does not spin
I thought my belt went bad....which it did, however there was another issue....The brush was not turning freeley, and would hardley turn at all, which caused my belt to go bad. Apparently, there are sealed bearings in the brush that you can not get to. If your brush will not turn, you can either spend some $$ and get a replacement. I opted to spend some time on mine, and soaked it in some Mr. Clean and water. I then sprayed brake part cleaner into both ends, and re soaked it. I then put some dish soap on either end and freed up the bearings. In between each of the steps I described above, I would try to work it by hand. I have not had a problem since, and saved some $$ too! Good luck and hope you get the same results I did;-)
Nov 08, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
My Dirt Devil ultra vision will not **** from base
Your belt is probably worn or broken. You need to replace the belt if you haven't recently. You can get the belts you need here:
Dirt Devil Ultra Vision Replacement Belts
Nov 07, 2009 | Vacuums
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Where is the belt on the dirt devil vision turbo cant find it
the belt is to the left of the brush. You need to revome the plastic covering (4 screws) to see it.
Oct 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Roller on my dirt devil vision not spinning
how do you replace a belt no.5 on a dirt devil vision.
Jan 31, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
I don't know how to change the belt on the dirt devil ultra vision no manual
Jan 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
493 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
