Question about Datalogic Falcon 4420 Handheld Barcode Scanner
I do not have the drivers to install on my WinXP desktop to be able to transfer data from the Falcon 4420 device.
    Scholar:
  • 125 Answers
Hey try this link: It has many different drivers and software for your device:
http://www.mobile.datalogic.com/Falcon%C2%AE-GUN-Model-4420_prd_stc1_1_SW.html
Posted on Sep 24, 2009
Testimonial: "Cool! Thanks for the quick response."
How to restart falcon 4420
Falcon 4410/4420(52 Key) - Press and hold the power button and insert a paper clip into the cold reset button below the Alt key
Jan 07, 2012 | Falcon 4420
Falcon 4420 scanners needs cmos battery replaced on the pc board. What is the part number the battery and how easy is it to replace?
dont know for sure but these are usually 3032 button style batteries, you can buy them at a local supermaket.
pop out or slide out once youve got the case open.
NB this is a very general solution, open the case first if breaking the warranty doesnt worry you.
Mar 17, 2010 | Falcon 4420
I have a 4420 falcon and it works only when the usb cable is connected to te computer in other words, the internet doesn't function when i disconnect it from the stand that has the cable connected to it....
I presume the PC you connect to has an internet connection. If so this is normal behaviour. When you connect to a PC via a USB cable and ActiveSync the connection is given an IP address via the host PC. If under the ActiveSync settings you are allowing the connected device to use the host PC's internet connection then the 4420 has access to the internet. simpuls.
To get a connection to the internet you would require a different connection, i.e. wireless.
You would also need a wireless access point or wireless router. Set the SSID and encryption on the wireless device and match it on the 4420.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Jan 17, 2010 | Falcon 4420
Can we upgrade our Falcon CE4.2 device to CE5.0
Yes....contact your rep. There is probably a cost to this. There is with every other manufacturer
Oct 29, 2009 | Datalogic Falcon 4420 Handheld Barcode...
Install WinXP SP2 to existing WinXP SP1
Files or data wont be erased but with some applications, you may need to reinstall drivers.
May 15, 2009 | Dell Dimension 4600 PC Desktop
Scanner doesn't scan all barcodes
these scanners are user configurable, to prevent scanning of an inappropriate barcode, only the required barcode schema are enabled, if you look in your code book you will find that there is a page with listings and examples of the various different barcode schemes, in the section before that there should be a list of barcodes that allow you to program the device to use whichever barcode scheme you wish (as long as it is compatible with the scanner)
so you can enable the scanner to read 128, code 39 or EAN and also you can configure prefixes / suffixes depending on your software's requirements
Oct 10, 2008 | Falcon 4420
USB 2.0 PCI Host Card CPQ5PHC
Let me know if your pc is running with winxp if winxp there will such problem doesnot exist. but in case of win98 you have to test drivers which is available in win98 and match to usb pci
follow this procedure
go to mycomputer
right click
select device manager
right click
click on scan for device
new hardware instalation wizard
search for new hardware
automaticaly update drivers
check one or more driver
try
and save which is compitable to your pci usb
Oct 16, 2007 | Micro Innovations MCNCPQ5PHC USB PCI Card...
this sounds to be an issue with your software, it is not from any of the standard installed software, try and cold boot the unit and reinstall any required software
Jun 04, 2007 | Falcon 4420
Datalogic Falcon 4420 Handheld Barcode Scanner Logo
721 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
