Question about LG VOYAGER VX10000 Cellular Phone
Pictures and Videos do not show up.
When I was going to look at my pictures, all of the pictures in "My Pictures" folder were black. They all still had the file name, but nothing was showing up. The same thing happened to my videos, but they were all white instead. What should I do?
Is there a software for any sizes of the pictures
Google has a picture manager program called Picasa 3, have found it can manage any piture and can edit them as well as an organizing by folders you already may have. It is a picture manager type program. It will search for all the pictures and videos on your computer and show you a list with folder names, times and dates.
All the picture and videos you have stay where they are located in your computer.
Please go to the link below at Google and you can download the program.
Follow the prompts and it will install and search for pictures and videos.
Good Luck
http://picasa.google.com/
Aug 27, 2011 | Computers & Internet
I need to know how to get my pictures on to my computer from my camera. do i need a disk. my computer don't have a hole for the chip. i do have the wire to connect to the computer. how do i go about...
To import pictures and videos from a digital camera
  1. Connect the camera to your computer by using the camera's USB cable.
    samshameem_2.jpgConnecting a camera to a computer with a USB cable
  2. Turn on the camera.
  3. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  4. (Optional) To tag the pictures, type a tag name in the Tag these pictures (optional) box.
    By default, the folder name includes the date the pictures and videos are imported and the tag name.
  5. Click Import.
    A new window opens and shows the imported pictures and videos.
Jan 08, 2011 | Computers & Internet
In trying to download video from our cam corder (Sony DCR-SR85) to our PC we get the following message 'Document management information can not be located" and we are unable to download the video files....
Different ways to transfer video:
Transfer the video to the computer using one of the following methods:
Use the Import pictures and videos option.
    1. In the AutoPlay window, click Import Pictures and videos using Windows .
    2. In the Import Pictures and Videos window that appears, click Import Settings .
    3. In the Import Settings window, assign the location on the computer where you want to copy the picture and movie files.
      • Next to Import images to click the Browse button and then select the desired folder (for example, My Pictures ).
      • Next to Import videos to click the Browse button and then select the desired folder (for example, My Videos ).
    4. Click the OK button.
    5. In the Import Pictures and Videos dialog box, click the OK button.
    6. Click the Import button.
  • Use the supplied Handycam┬« Utility application.
    1. Start the Handycam Utility application bundled with the Sony® Picture Utility software.
    2. In the Handycam Utility window, click to the select the type of files you want to transfer: HD movies , SD movies or Pictures .
    3. Click the Import button.
  • Copy and paste the video files from the Removable Disk window that represents the camcorder.
    1. On the computer desktop, create a new folder.
    2. If the Removable Disc window is not showing, open the My Computer window and then click to select the Removable Disk icon.
    3. In the Removable Disk window, click to select all the folders and files listed.
    4. On the keyboard, press the CTRL+C keys to copy the folders and files.
    5. Open the new folder that you created.
    6. In the new folder, press the CTRL+V keys on the keyboard to paste the folders and files into the new folder.
    7. Rename the new folder.
Oct 21, 2010 | Cameras
Computer does not respond to camera being on and plug in
  • Start EASYSHARE Software.
  • From the menu bar, select Help > About Kodak EasyShare software.
  • Note the software version. If you have Version 8.0 or later installed on your computer, review the help information for Transfer Pictures.
  • From the menu bar, select Help > Kodak EasyShare Help.When the Welcome to EasyShare Software window appears, select Transfer pictures, then read the help information.
  • If you do not have Version 8.0 or later installed on your computer, go to EASYSHARE Software Downloads, then follow the instructions to download the latest version of software. Approximate download time is 5 minutes for Cable/DSL, or 2 hours for a dial-up connection.
If that doesn't solve your problem you can manually add your pictures/videos to easyshare software.
  • In easyshare Software, select My Collection, then select Add Pictures. The Add Pictures screen appears.Look at the Select a location field. If the My Files folder is collapsed, click the + to open the folder.In the Select a location field, select your camera folder, for example: M381 Digital Camera. Thumbnails of the pictures/videos on your camera internal memory, and on a memory card if one is in your camera, appear.
  • Select the pictures/videos to add to EASY SHARE Software, then click Add Pictures. To add all the pictures/videos in the folder, click Add Entire Folder.Click Done.
Thank you !!
Jun 25, 2010 | Kodak Easyshare C813 Digital Camera
Pc wont recognize camera. windows xp
Thank you
Jun 23, 2010 | Kodak EASYSHARE M340 Digital Camera
How can i upload pictures and videos to my psp using pc?
Hi faith_manio, Based onyour concern, I suggest trying the following steps: 1. Connect the PSP to your PC with a USBcable. 2. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 3. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 4. Press the "X" button, your PSPshould display "USB Connection". 5. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 6. Click on the drive letter thatcorresponds to the PSP unit. 7. Now create a new folder on that drive andname it "psp". 8. Within the new "psp" foldercreate another folder, and name it "pictures".
--> the same procedure if want to put video on your psp, just create video folder.
9. Copy your desired files into the new"pictures/video" folder. 10. When you're done copying your desired pictures and videos, press the "O" button on the PSP to get out of USBconnect mode. To play video, Use the left-right arrows to move to the Video area, then theup-down arrows to find "Memory Stick". Chose that folder by pressingthe "X" button again, and you should be able to find all yourfavorite movie!
--> to check your photos, just go to picture area. Chose that folder by pressingthe "X" button again, and you should be able to find all yourfavorite photos! Hope ithelps, Thank youfor using FixYa.
Feb 14, 2010 | Sony PSP (Piano Black)
No My Videos, My Music folder in XP Media Center
HI drkravenbrow,
It's as simple as going into my documents and adding a folder called My Videos. It needs to sit inside the my documents folder.
Good Luck,
Don't forget to leave a rating,
Mark
Sep 21, 2009 | Microsoft Windows XP Media Center Edition...
How do i put pictures and videos on the opal mp3? it shows the icons in the menu but i dont know how to do it?
make a new two folder each have the name pictures and videos then put pictures in the pictures folder and videos in the videos folder
NOTE:-
you should make the folder in the mp3 drvive
Jul 11, 2009 | RCA OPAL M4001 MP3 Player
Camera Videos wont download properly
Videos generally run in AVI mode. When putting pictures into the computer, place them in the "My videos" folder instead of the "My pictures" folder. This should solve your problem.
Apr 07, 2009 | Cameras
Cant save pictures
QuickCam Gallery
Your pictures and videos can be viewed in the QuickCam gallery. To view your pictures in the Gallery:
  1. Launch QuickCam (Start > Programs > Logitech > Logitech QuickCam)
  2. From the QuickCam menu, click the QuickCapture button as shown below:
  3. View your pictures and videos in the Gallery area located below the main QuickCapture window as shown below:
For the picture gallery, click in the picture icon:
For the video gallery, click on the film icon:
My Pictures / My Videos Picture Files:
You can also view your pictures and videos by opening the QuickCam folder in My Pictures or My Videos. To see your pictures this way, do the following:
  1. Open the My Pictures folder (Start > My Pictures) as shown below:
    NOTE: If you have Classic view in Windows XP, simply open the My Documents folder on your desktop and then open the My Pictures folder.
  2. Open the QuickCam folder.
  3. Your pictures will be shown as follows:
  4. To view your pictures, double-click and they will open in the Windows Picture and Fax Viewer or any other picture viewer you have set as your default picture viewer on your computer..
Video Files:
To view your video files:
  1. Open My Documents folder as shown below:
  2. Open the My Videos folder:
  3. Open the QuickCam folder:
  4. Double-click on the video file you wish to view and it will open in Windows Media Player or any other video player you have set as your default video player on your computer.
Jan 15, 2009 | Logitech QuickCam Communicate STX Personal...
LG VOYAGER VX10000 Cellular Phone Logo
69 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
