Question about Coffee Makers & Espresso Machines
I need parts for my iberital ladri cooffee machine - 1 single group head arm and a double group head arm
    President:
  • 1,618 Answers
Easiest location is espressoparts.com
Posted on Oct 08, 2009
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
My silvia is at least 8 years old and is serviced on a regular basis.
The 'group seal' in the underside of the head that the grounds arm compresses against probably needs replacing. If you unknowingly left a few grounds to dry on the underside of the seal the last time you used the machine, this can be enough to cause a leak the next time around.
If replacing the group seal, replace the 'shower screen' above it as well. Always buy genuine Rancilio parts, you should be able to find both for around $10 - $15 each on Ebay.
There are videos on either You-Tube or Gooble that show how to replace these parts on the Silvia.
Always try to ensure the seal face is cleaned before and after use and the group seal will last longer, but they are actually meant to be replaced whenever necessary, they are not designed to last forever.
Jan 13, 2013 | Rancilio Silvia Espresso Machine
How do i use cleaning powder
Hi Dont use the cleaning powder yet. Remove the group head shower and clean it with steel wool, then clean the group head where the shower sits with sfeel wool. Remove the filter fron the group handle and clean the under side. Also clean the group handle before you put the filter back in. You shouldn't use powder in these machines, but if you do, you need to put a blind filter (filter with no holes in it)in the group handle. If you dont have a blind filter, you can use foil to cover your filter. When you have done that, you need to add a 1/4 teaspoon of powder into the foil covered basket and lock the handle in the group head. Switch the coffee button on for a few seconds then off again.Domt take handle out yet. Repeat this on/off proceedure 5 or 6 times. Now remove the handle and flush out any powder that is left. Leaving the foil in place, lock the handle back into the group head and repeat the above proceedure. This fushes out any powder residue. Make a coffee and discard. Now your machine has bee back flushed. Again, i do not recomend using powder in these machines. The poder can back flow into the boiler. Just make sure you give it a good flush. If you clean your group head and shower weekly, you'll never need to use powder. Dazza COFFEE MACHINE TECHNICIAN
Sep 26, 2011 | Rancilio Silvia Espresso Machine
Hi i have bodum grandos espresso, i need a new group head and water tank where can i find in Sydney?
Hi I have the same machine that has been taken apart and so it's now a pile of spare parts. When you say new group head, do you mean the collar of the group head, or do you need a new group handle and basket ? I live in Sydney if you want to get in touch.
Mar 25, 2011 | Bodum GRANOS (3020-16US) Espresso Machine
I have a Starbucks Sirena - the grounds overflow in the basket while pulling shots, and it drips forever after it's done. When I remove the basket it's a huge mess every time. All the parts seem to be...
it sounds like you need a new group head gasket, or the group head gasket is not installed properly.
If it is a new machine, you probably just need to reseat the group head gasket. If it is a used machine, the gasket is probably worn, they need replacement every 6-12 months.
The Starbucks Sirena is made by Saeco, and is also called the Saeco Sirena.
You can find the group head gasket (brew head gasket), and any other parts from the following:
seattlecoffeegear.com
Here are a few videos of the machine in use:
http://www.youtube.com/SeattleCoffeeGear#p/search/3/6QlOKdAhElI
http://www.youtube.com/SeattleCoffeeGear#p/search/1/U8Lyomhq92Q
Mar 03, 2011 | Saeco Starbucks Sirena Espresso Machine
H owdo you clean the machine using the tablet ? Thanks
  1. Turn machine off.
  2. remove group head (portafilter)
  3. place single or dual cup filter in group head.
  4. place rubber bung in group head.
  5. place one tablet in space in bung.
  6. replace group head in machine.
  7. This is where the instructions lead you astray.
  8. DO NOT PRESS 1 & 2 CUP BUTTONS SIMULTANEOUSLY WITH POWER BUTTON.
  9. Press & hold 1 & 2 cup buttons simultaneously, on their own.
  10. Now press the power button while still holding the 1 & 2 cup buttons.
  11. Cleaning cycle will start, and will take around 5 mins to complete. Book says it will beep 3 times when finished haven't heard this yet. Just wait a couple of minutes extra and all should be well.
  12. Clean me light should be out and tablet disolved if not repeat steps again until tablet disolves.
Dec 08, 2010 | Breville Fresca BES860 2Cup Coffee Maker
My machine has worked beautifully for several years, but suddenly, I have issues with the group head. When trying to pull my espresso, I get leakage around the rim of the group head. Sometimes coffee...
I have had the same issue, this is just the group head gasket that needs to be replaced. I got all the parts and I am going to try and replace it myself
Jun 09, 2010 | Pasquini Livia 90 Espresso Machine
I have an Astra Mega I single group espresso machine 110v. I seem to not be getting enough water through the portafilter and it is all clean.
Remove portafilter, shower and screw and run the head. Did you get a nice steady flow or a weak drip. If a weak drip then the solenoid or the metering jet on the head is blocked and needs to be cleaned. If you get a nice flow the adjust the grind on the coffee to coarser.
Jan 15, 2010 | Astoria Divina SAE-1 Espresso Machine
Coffee Makers & Espresso Machines Logo
126 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
