Question about Kenmore 62602 Electric Dryer
Kenmoore dryer i think my dryer is electric since its only hooked up to the electric plug. its been working fine except that whenever i dry, my place gets really hot, like the heater is on. when i was cleaning, i noticed that there is a vent or a large coil in the back which is not connnected to the dryer, is this the problem? the vent is quite long for the space so its a little messed up. i guess ive been drying clothes with the vent or the large coil unhooked, is this safe? what do i do?
    Master:
    Sergeant:
  • 482 Answers
Hook it back up. you need to vent it out side.
Posted on Dec 16, 2007
I have an Asko T700 dryer which is working fine except tripping after half or less of drying time. I can reset and it dries for a while longer, usually tripping again. I have cleaned out the lint and...
Well, if the vents are perfectly clean and unobstructed the only thing I can think of is that the thermal switch designed to turn off unit when overheating is opening prematurely.
Might have to be replaced.
Sep 06, 2017 | Asko T700 Electric Commercial Dryer
My dryer does everything it is supposed to do except fully dry the clothes. I took the back off and cleaned everything. I even pulled the heating element out and made sure all the coils were heating up. It...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 03, 2010 | Estate TEDS840JQ Electric Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Maytag Performa Electric dryer timer is bad
Look up an appliance parts store in your area. If there is no appliance store, try www.searspartsdirect.com.
If it does not turn off during timed dry then it for sure has gone bad. If it takes a while on timed dry then it is most likely that your thermal fuse/ valve coils are going bad.
Jan 14, 2010 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Dryer makes noise and vibrates when starting and stopping
Most likely it is the bad blower wheel. The clothes seems hotter than normal oh yeah bad blower wheel.
May 19, 2009 | Whirlpool GEW9200L Electric Dryer
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
Dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Mar 01, 2007 | Asko T731 Electric Dryer
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
