Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
NEW HOME TO ME NO REMOTE DO NOT KNOW KEY PAD NUMBER TO KEYLESS ENTRY #1021499A
    President:
  • 3,197 Answers
On the rear of the motor unit near where all those white wires go you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in any 4 digit PIN you like and press enter. On the opposite end of the motor unit you will find the model number. You need this to get the correct remotes.
Posted on Sep 24, 2009
Sim number for Pontiac torrent remote?
2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob ...
www.amazon.com/...Pontiac-Torrent.../B009E9LX5O
Amazon.com, Inc.
Rating: 5 - ‎4 reviews
Amazon.com: 2007-2009 Pontiac Torrent Keyless Entry Remote Key Fob With Free ... Manufacturer Part Number, Part #: 15913420, 20869056, 20952475 ...Missing: sim
2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button ...
www.amazon.com/Pontiac-Torrent...Remote/.../B0068...
Amazon.com, Inc.
Amazon.com: 2008 08 Pontiac Torrent Keyless Entry Remote - 4 Button Models with ... GM Part Numbers: 20868672, 20952474, 15913421 w/ Remote Starter ...Missing: sim
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ...
? 3:28
https://www.youtube.com/watch?v=OASrgxUXXdI
Nov 7, 2012 - Uploaded by Lessco Electronics
2007 to 2009 Pontiac Torrent Factory Remote Transmitter ... Press the set/reset button until REMOTE KEY ...Missing: sim
Jan 31, 2016 | Televison & Video
Venza remote keyless entry problems
I have the 2010 Toyota Venza push to start. I lost the original key, so i bought a new key with the remote and its was programmed successful but this remote only had the three buttons on it, instead of four buttons ( Including the Hutch button). So i bought another new remote with the four buttons today and I want to know if it will work when i switch the programmed key into the new remote?
Feb 04, 2012 | Toyota Venza Cars & Trucks
My keyless entry pad stopped working replaced the battery and still will not work. I have a 2001 ford taurus ses. how do i resolve this problem by reprogramming the keyless entry pad? I tried the code lock...
Try it with a new remote pad, turn the key back and forth untill the locks jump up and down.. do it slowly , when they jump make sure to leave the key in the on position while pressing both lock and unlock buttons on the remote, they should then jump again telling you that the remote is now programed.
Apr 14, 2011 | Ford Taurus Cars & Trucks
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
My keyless entry remote was working and all of a
Do you mean the remote fob or the key pad on the side of the car. Fob could be batteries.
Feb 05, 2010 | 2005 Ford Expedition
Cannot find code for keyless enrty pad on door on a 2003 linclon
you have to contact the dealer.then give them the VIN number they are the only ones that have it
May 30, 2009 | 2003 Lincoln LS
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry keypad
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Mar 08, 2009 | 2003 Ford Taurus
Reprogram a keyless entry remote
Hello
this is how to program the remotes/keyless entry
How
  • Obtain all remote transmitters
  • enter the 5 digit permanent code into the keyless entry pad on the drivers door
  • Press the 1-2 switch on the keyless entry pad
  • Within 5 seconds
  • Press any button on the first remote transmitter
  • The doors should open then lock
  • Within 5 seconds
  • press any button on the second & third remote
  • within 5 seconds for each remote
  • to exit programming
  • simultanionusly press 7-8 & 9-0 switchs on the key pad or wait more then 7.5 seconds
NOTE
The 5 digit permanent code is located in one of the following places
  1. On the owners warranty card
  2. On the label on the inside the trunk/ boot
  3. On the owners code card
  4. On the centrel locking control module located in the drivers door
  5. In the PCM ford can get this for about $25.00
I hope this help
Regards Paul
www.limotec.co.uk
Jan 13, 2009 | 1995 Lincoln Town Car
Door handle stuck
need to remove door panel either the linkage clip either broke or disconnected --if have remote start on fob need dealer to program--if normal try these links
Lexus Free Keyless Remote Fob Entry programming instructions Free Keyless Remote Fob Entry programming instructions procedures for all...
May 13, 2017 | 1998 Volvo V70
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
200 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
