Question about Nokia 3110 Cellular Phone
It asks to foramt memory card..where is that option
Whenever i click on memory card...a message pops up to format the memory card..how would i format my memory card?
There is no format option available in Nokia 3110. Please suggest
  • pratapsingh7 Sep 25, 2009
    where is answer...it is just my question again..
My memory card is not opening
Your card may not be formatted -or- it is and it;s a proprietary format. If you want to format it, here is the instructions (for Windows):
Put your card into your computer (some have a slot or else use a card reader). Right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
Dec 21, 2011 | Kingston 2GB Secure Digital Memory Card
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
Dwhenever i insert my memory card it says memory card not formatted do u wnat to foramt? even after i press ok it says the same message
DEAR FRIEND,REMOVE YOUR MEMORY STICK FROM YOUR PHONE AND CONNECT IT TO A COMPUTER USING A MEMORY CARD READER, THEN FORMAT IT FROM THERE.
Feb 22, 2011 | Nokia 6300 Cellular Phone
My pc can't read it and autoplay doesn't stop popping out
if the autoplay option pops out after u insert ur memory card that means tat ur pc is reading it but the memory card may be corrupt slightly; for fixing tat try to format ur memory card , to format ur Mc go to "my computer" ur Mc icon is displayed there right click on tat icon ul find "format" option click on it n another tat opens press start wait till ur Mc is formatted then you remove n insert it again it will work fine
Sep 17, 2010 | SanDisk 2GB microSD Memory Card
Format memory card
Hello :
* Turn on your computer and put the SD card into the card reader slot on the front of your computer or the external card reader attached to a USB port. Wait to see if your operating system automatically opens a window prompting you for information. Click on the option to "Open a folder to view files" if the window pops up.
*Click on the "Start" button if your operating system does not automatically prompt you to open a folder. Choose the "My Computer" option to bring up a new window.
*Right-click on the drive bay for your card reader, and then choose the option that says "Reformat" from the pop-up menu. Click on the option to set the formatting to "FAT16" if you receive a separate pop up window asking you which file system to set the card to.
PLEASE RATE .
good luck .
Apr 09, 2010 | SanDisk 2GB microSD Memory Card
I have an lg xenon, i didnt get a book with it so how do i format the memory card i got for it?
You have a two options:
1) Easiest option: Insert the card into your phone, go to "Options => Advanced Options => Memory Card". Press the scroll wheel and select Format Card.
2) Format the card with a computer:
*Plug the memory card in your computer by using either a built-in card reader or a multi-format USB Memory Card Reader. This can be bought at any computer store / online retailer.
*Right-click on the drive in "My Computer" and click format. Click on format in the dialog that pops up. Now you can insert the card into your phone.
Feb 24, 2010 | LG Cell Phones
How do i go about formatting my kingston sd card, step-by-step?
Insert card into card reader. Find which drive letter the card is in. Right click on that drive. You will see an option that says format. A warning will tell you anything on the drive will be errased. Once sure you have the right drive click OK.
Nov 28, 2009 | Kingston 4GB Secure Digital High Capacity...
My Blackberry Curve 8330 won't format a media car
From the Home screen of the BlackBerry smartphone, click Options > Media Card or Options > Advanced Options > Media Card.
Display the menu and click Format Card.
  • some times Format Card option does not appear on the menu, skip the step and perform the procedure that follows.
  • A warning message will appear asking if you are certain you would like to format the card. Click Yes to continue.
    If the Format Card option does not appear on the menu, complete the following steps:
  • On the Media Card screen, set the Mass Storage Mode Support field to Off.
  • Display the menu and click Save. The Media Card screen closes automatically.
  • Click Media Card to reopen the Media Card screen.
    To format the media card, display the menu and click Format Card.
Nov 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell phone how do you format the sd card?
just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
Feb 20, 2009 | Nokia Cell Phones
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Nokia 3110 Cellular Phone Logo
69 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
