Question about Kenmore Dryers
Dryer does not heat up. tumbler does work. - Kenmore Dryers
  • 301 Answers
Gas or electric dryer? If it is electric the heating element may be bad or a thermal limit switch near the heating element may be defective. Is the outside vent plugged?
Posted on Sep 24, 2009
Dryer does not heat up when drying. Tumbler works but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101././
May 03, 2011 | Kenmore HE2 Plus Front Load Washer
My dryer is 4 years and the heater wont heat up but the tumbler tumbles
First check your dryer vent, make sure that it is venting properly. If that doesn't work then it is your dryer heating elements.
Apr 27, 2011 | Frigidaire Dryers
Breaker popped, so went and turned it back on. Now there is no heat. What could be the problem?
In your dryer behind the tumbler there are coils with insulators. up against the dryer wall their should be many holes that allow the heat to come into the tumbler. run your dryer about 3 minutes with settings on heat , then open the door and peer thru to the back while the tumbler is spinning. if you don't see part or full radiat heat. the heating coils will have to be replaced. you can purchase them from most appliance parts store. just make sure you provide the brand and model # and possibly the ser#. good luck!
Dec 30, 2010 | Dryers
Lower dryer tumbler will not heat up, upper dryer part works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Dryer heats okay, but it doesn't run.
You likely have a broken tumbler belt. You will need to replace it.
May 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Tumbler spins, heat won't go on, timer won't work
It is your operating thermostat. It controls the heat and runs the timer down.
Jul 07, 2009 | GE DVL223GB Gas Dryer
Maytag electric dryer. Tumbler won't turn.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
Dec 08, 2008 | Dryers
GE Profile Electric dryer - not heat, damp clothes but tumbler works
first checkyour breaker it may not look like it is tripped but cut it off and on or maybe the thermo fuse or you element is bad you have to check proper voltage to parts
Apr 20, 2008 | GE Profile DPSB619ED Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
