we have a Fellowes Powershred C-220C and the sensors for stopping it run in between shredding are not working - it keeps running while shredding - is there anyway to fix this??
Only if you are mechanically handy and know how to take a part. Most of these shredder's sensors are PLASTIC and break EASILY. I should know, I had to take apart my wife's shredder.
I had to bypass the sensor and rewire it. It can be done if you know what you are doing. If not, don't try it
In your case I would unscrew the top assembly. Than I would use a can of canned air to clean out the sensor eye. Than I would use tweezers to pull out all specks of paper I could find.
Your best bet is to try to return it for a replacement.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thanks! I will see if our janitor can fix it
Bev
" - bmelanson
the main drive gear on my universal UNV-38082 medium duty paper shredder is stripped. i need a...
(More)
the main drive gear on my universal UNV-38082 medium duty paper shredder is stripped. i need a replacement or the specifications on the gear to look up a replacement.
we have a Royal paper shredder model number RS9512c. The gear that turns the cutter has several...
(More)
we have a Royal paper shredder model number RS9512c. The gear that turns the cutter has several teeth missing. Where can we get a replacement part?We are in Lexington NC
basket full sensor cleaned off. object in sensor cleaned off. motor works fine in reverse. shredder...
(More)
basket full sensor cleaned off. object in sensor cleaned off. motor works fine in reverse. shredder turns freely in reverse. It looks like nothing is stuck in the shredding teeth. When the unit is put back in the run mode, the paper jam light turns back on. what is the problem?
Hello, 220-2 is not shredding after the paper jam was cleared, when the door is opened the red light...
(More)
Hello, 220-2 is not shredding after the paper jam was cleared, when the door is opened the red light comes on and off when closed. That was it and no other buttoms seems to be responding. Any suggestions, Thanks
