Question about Ruud UBHC Air Conditioner
Trane Heat Pump
Had a 2 day power outage recently, heat pump has not worked since. The programable thermostat reads aux heat on.
    Sergeant:
  • 288 Answers
What caused the power outage? Check the outdoor disconnect to the condenser unit. The fuses may have blown, causing the heat pump to not function and depending on the aux. heat to carry the load.
Posted on Dec 18, 2007
WHAT DOES IT MEAN WHEN HEAT IS SET 66 AUX IS FLASHING
If it is a heat pump if the ambient I door temp is not than 3 degree s lower than 66 it utilizes the aux heat ( heat strips) to help the unit achieve your desired temperature set point faster. Also the heat pump does need help if trying to overcome really cold temperatures. Once set point is achieved the heat pump should be able to keep the home at the set point without aux heat. But the flashing may just be to let you know that the heat strips are in use at the current time. See if when the temperature gets close to your set temp if it goes away. If not a heat pump it may always flash to just tell you heat strips are in use. Some homes mostly trailers only have heat strips but on heat pumps heat strips are there to help heat pump get to your desired temp. But when your heat pump can maintain the temp without the strips is where it saves power. Also heat pump thermostat hVe emergency heat settings. This scares alot of people but if your heat pump isn't working and you have to switch it to emergency heat until you can get it fixed,. That means that the system is only using heat strips and not utilizing heat pump at all. Power bill may be a little higher but remember, most trailer homes only have heat strips and if you do not use emergency heat in this situation your heat strips will only heat home 3 degrees below set point on thermostat to allow heat pump to bring it up the other 3 degrees. If heat pump isn't working correctly you will always be 3 degrees colder than what you set you thermostat at. Maybe too much info but it's prolly just your aux heat on helping system achieve the desired temp you set thermostat too.
Oct 24, 2016 | Heating & Cooling
What does it mean when the aux is flashing on my thermostat?
I assume that you have a heat pump system. If this is the case, the outside temperature is probably lower than the heat pump is sized for and it is using the auxiliary heating system to keep up. The auxiliary heating system usually is an electric coil in the heat pump unit which supplements the heat being produced by the heat pump. This is normal operations and does not indicate a problem with the heat pump, it is just really cold outside. If it is not colder than usual outside, there may be a problem with the heat pump and you should call a heating contractor to check it out.
Jan 10, 2015 | Emerson 1F89EZ-0251 Blue 2" Thermostat,...
Why is my Duo Therm Heat Pump Running in Aux Heat Mode?
If the compressor is running in heat mode but not producing any heat then the change over valve may be stuck. That is a job for a pro. If the thermostat isn't applying power to the changeover valve then a thermostat change is easy to do.
Aug 18, 2014 | Heating & Cooling
Heater problem
Is the unit a heat pump? If so then check the aux heat relay to see if the electric heat strips come on.
Feb 05, 2014 | Honeywell PRO 4000 5-2 Day Programmable...
Just installed Honeywell RTD7500d thermostat to replace Batstat239 (which seemed to have faulty temperature gauge - it would keep pumping both hot and cold past the set point indefinitely). I followed the...
Wiring seems right, but it needs to be wired like the original tstat. Meaning if W was connected to w1 on the old, that's were it goes on the new. If it was on aux heat then your wiring seems correct. If its operating the aux heat "on its own", then that's were your issue is at.(?) Also, there is a configuration menu in the new tstat. It needs to be set up for your system, heat pump, 1 cool, aux heat or 2 heat 1 cool, O should engage the reversing valve(RV=O). If you didn't write down or pic what you started with, it will be tough for you, and us, to wire your unit correctly. And there is no factory installed fuse on the outdoor. The indoor will(should) have a 3 or 5amp "blade" fuse, (car fuse but not the new smaller style, the 80's to 90's style). Its on the indoor circuit board. Hope this helps!
Feb 28, 2017 | Heating & Cooling
Removed my non programable Honeywell RT 5220D replaced it with a Honeywell RTH6350D to run my Goodman Heat Pump. First I labeled the wires then connected wires as follows: AUX, G, C, O/B (orange wire)...
Leave the factory jumper between R & RC. Connect the wires to the new stat just as you have them labeled. Use a piece of thermostat wire to make a jumper from AUX to E terminals. Your new thermostat should give you instructions on how to access the installer set up. You are going to set it up as heat pump with aux. I see this is 2 days old but if you need any help let me know.
Feb 13, 2011 | Honeywell Programmable Thermostat Heater
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Thermostat says ''Aux heat on'' and buzzes when we turn on heat
You most likely have a heat pump, the aux heat (usually electric) comes on anytime the room temperature is 4 degrees below the thermostat setting. Does the buzz go off when the aux heat lite goes out? If the aux heat does not shut off then the primary heater (heat pump) is not putting out enough heat to satisfy the thermostat. I need a little more info. Do you have a heat pump? Is it working?
Nov 19, 2008 | Honeywell Electronic Programmable...
Ruud UBHC Air Conditioner Logo
276 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Dennis Boxerman
John Tripp
John Tripp
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
