Question about Magic Chef CTB1922 Top Freezer Refrigerator
Ctb1925gr top freezer completely defrosted w/o notice--all items defrosted in freezer. Refrige is frost free--should this happen--are there certain periods the freezer should completely defrose.Fridge 6-7 yrs old!!! This happen over night and now freezer is working again!!!
  • Magic Chef Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 20, 2010
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
My side by side Fridge has been running at 13 degrees for a few days.,the freezer is normal. We noticed some "ice build up , took the cover off and all the elements etc... were iced over, we have...
This is what is happening. All "frost free" refrigerators are not truly frost free. The cooling comparment elements frost up with moisture from the air. Every 6 or 8 hours or so the fridge shuts down. then . small electric heaters fitted into these cooling elements melt the frost away. The water goes down a tube into what is called a drip pan mounted underneath the fridge. If the drain tube clogs with a piece of paper, or food or algae. The water from the frost melting stays in the pan because the drain is clogged. So each time the fridge defrosts, it builds up ICE not frost and eventually it completely clogs with a block of ice.
The other thing that can happen, is that the timer that controls this cycle fails and the heating elements never turn on. The the fridge then clogs with frost. The fridge will clog with frost if any of the following parts fail. The defrost thermostat which opens up the heater circuit when the coils reach
around 40-50 degrees, the defrost heaters mounted in the cooling coils, or the defrost timer fails.
If your fridge works normally after this, then the drain hole was clogged and you unclogged it. If it gets colder and colder again. Then the timer, defrost thermostat, or the defrost heaters have failed.
Hope this helps. You are welcome to write back to me and tell me what is happening with your fridge. I hope this helps, Best Regards, Mark
Dec 28, 2010 | Refrigerators
Over under Amana split door top frig
You may have an issue with a defrost component (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 14, 2010 | AEG S70408KG Bottom Freezer Refrigerator
I hear a popping/clicking type noise from the freezer and I don't think the fan is coming on. It doesn't have an ice maker. The contents are still frozen each day, but I notice a thin layer of frost on...
if temps are still good, with settings at normal, that popping noise you hear is likely the resulting temperature change when the defrost heater comes on. when its in defrost, you may hear the clicking of the defrost timer, which you wouldnt normally hear when the unit runs.
You say there is a thin layer of frost on certain items, where are these items located in your freezer? are they near the top, the bottom, the back, the front, combination thereof? Are you having any problems with the door not closing well? check your door gaskets, are there any tears, rips or gaps. if you place a dollar bill between gasket and frame, does the bill move, ON ITS OWN. Of course you will be able to move the bill, but if you close the door on the bill and it falls out or shifts position by itself, you have a seal problem. Do you have too much food inside the unit? If you only noticed the frost recently, perhaps you cleaned it out and something is obstructing door from closing completely, on its own. Or if you went shopping, perhaps you bought just a little too much food. check the bottom drawer if yours has one, is it pushed all the way in?
Mar 24, 2010 | Freezers
Frost free freezer in my frost free refrigerator
the noise is quite possibly the freezer fan cutting ice behind the wall
you may have an issue with your defrost system
Oct 06, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Freezer gets cold refrige stays warm kenmore model# 106 44563600 side by side no ice maker
by cold do you mean at freezing temps or just cold if so do you see frost on the back panel of frzr if so req defrosting if is a self defrst three item could be bad morelikly its one the defrost heater or bi-metal thermostat on top of evap or the defrst timer if need rapid move the frzr item in cooler get hair dryer and thaw the frzer can you remove the rear panel without much work it would work better this way. now this is a short term fix before you get tech out or not it will have to be failed again so he/she can solve this problem
Aug 19, 2009 | Kenmore Refrigerators
Freezer & freezer work fine. Water stops when refrige is set at 38 degrees. To keep water from freezing we have to set the refrige temp to 40 degrees, but find that temp not cold enough. Water can...
It may have auto-defrost or frost-free feature that is not operating. Also there is a drain tube that goes from the compartments to the bottom of the fridge where the evaporator pan is. The tube may be plugged.
Jul 02, 2009 | Samsung RS2556 Side by Side Refrigerator
Kenmore top-freezer fridge makes a loud grinding noise for different periods of time - sometimes for 10 seconds and sometimes for 5+ minutes; and sometimes it won't happen for a week and other times it...
Remove the back wall of freezer. If the coils are frost solid youll need to advance the defrost timer(top inside refrige part) w/ a small flat screw driver, the defrost heater should glow red within a good minute. also youcan turn blade to be sure it is bracked and unobstructed.
Mar 21, 2009 | Kenmore Refrigerators
Freezer works and fridge on top doesn't
Check behind the back wall for frost build up if the is a defrost problem this is the first sign
Mar 14, 2009 | Kenmore 71279 Bottom Freezer Refrigerator
Unknown water leak from the ice maker, thus freeze build up
the frost on the back wall tells me its not defrosting.this will happen 2 to 3 times a day.if defrost system working their would not be frost.hencethe term frostless.to con firm this sence you defrosted this unit it should work in all ways for a day or 2 lets stop here and you let me know what happens
Dec 31, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Magic Chef CTB1922 Top Freezer Refrigerator Logo
177 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
