Question about Microsoft SideWinder Force Feedback Wheel Wheel And Pedals Set
Re: Problem with SideWinder Force Feedback Wheel (USB) and Windows Vista. I have two PC's, one running Windows XP Home and the other running Windows Vista Home Premium. Both correctly recognize the device by name, but on running Control Panel / Game Controllers I have discovered a discrepancy between the versions of Windows. My SideWinder Wheel has the following codes. Part No. XD4-97607 Product ID 52178-579-2882895-00000 On calibration I get the following values. XP Accelerator pedal: Y Axis 31 - 0 (Off - Fully Depressed). Brake pedal: Y Axis 31 - 62 (Off - Fully Depressed). Wheel: X Axis -512 - 511 (Left - Right). Z Rotation: No effect. Both my applications which use the wheel work perfectly on this machine. Vista Accelerator pedal: Y Axis 63 - 0 (Off - Fully Depressed). Brake pedal: Z Rotation 63 - 0 (Off - Fully Depressed). Wheel: X Axis -512 - 511 (Left - Right). Neither of my applications works correctly, although both have no problems running under keyboard control. My Vista PC is fully updated as of 18/09/09. sincerely, Alan Romp.
  • 1 more comment
  • rompad Sep 25, 2009
    To VinayT,
    your response does not answer my problem. The problem is to do with how Vista works with this device. There are no settings to change. I presume this is a fault with the driver for this device.\
  • rompad Oct 01, 2009
    I have tried your solution but it has not helped. I am not sure that this problem is well understood.
    The problem concerns the axes used for input.
    On XP (and previous windows) the X-axis is used for left and right steering, the Y-axis is used for accelerator and brake pedals (half the range for each) and the Z-rotation axis is not used at all.
    On Vista the X-axis is the same but the accelerator pedal works on the Y-axis but the brake pedal works the Z-rotation axis.
    If you cannot help with this problem perhaps you could tell me how to send an email to Microsoft. The only way I have found so far only allows a brief question and I would like to send an email which describes the situation. After all this is a Microsoft product failing to run on Microsoft software. Or perhaps you could pass this on to Microsoft.
    regards, Alan.
    Could you tell me how, in Control Panel / Game Controllers, to change how the calibration works?
    Alan.
Hi there
It does indeed sound like a Vista compatibility issue. The drivers may be confusing the correct axis for the brake and applying it to the Z axis by error.
Your best bet may be to ask Microsoft to confirm if the device will or will not work correctly under Vista. You can try to contact them here.
In past experience, I have been able to get the non force-feedback version of the same wheel to work under Vista by simply plugging it with the USB connection. No extra software was required, it would just detect and then work in games.
If you go to Game Controllers in Control Panel, perhaps you can remove all the listed controllers and reattach the device to the PC and see if it works correctly with games?
Posted on Oct 01, 2009
  • 360 Answers
Did you try another USB port. Sometimes that's what I have to do. Plus, I have to turn off my machine unplug it, hit the power button, plug back in and turn on the machine. Then things work right, and I haven't solved that, yet. Vista usually works pretty good but, it looks a little backwards by your data. I could tell you to reinstall your drivers and software, I suspect you have so, try my procedure to turning off the machine. Hope this helps. If I come across new information I'll add a comment. I hate when things hang ups too.
Posted on Sep 25, 2009
  • Richard Klein
    Richard Klein Sep 30, 2009
    This may be a incompatibility issue.Matter of fact I'm sure it is. Go back to XP!
    President:
  • 1,884 Answers
Cant you change the setting in Vista to what they are in XP. Then it may perform similar to what it performs in XP. Try it.
Posted on Sep 24, 2009
I have a 25 pin microsoft sidewinder force feedback pro joystick which I use with a flight simulator. After updating to win 7 x64 I need to convert this to usb for the hardware to be viable. Any...
hey m8,
stumbled over your post while searching for sullotions for the same kind of problems.
I also have a perfectly working M$ sidewinder FF pro, trying to get it to work WITH force feedback.
However I am affraid there is no way to do this. From what I read is the gameport to slow to keep up with nowaday PC speeds :(
I got the joystick working up to windows XP (in XP it lost its FF tho and slowed down gameplay sometimes. Not sure if that was caused by the joystick or the game itself running in some compatibility mode). I was using the gameport from an old soundblaster live! by the way.
I did find something that may be usefull for you tho. Check the link below:
http://social.technet.microsoft.com/Forums/en/w7itprohardware/thread/20fa2ccd-061b-4864-abbd-96d1a9871a2f
I havent tested this yet myself and it will require a creative soundcard but I think it will have a better chance of working that using some converter from gameport to USB.
Nov 15, 2010 | Microsoft SideWinder Force Feedback Pro...
Is the sidewinder force feedback wheel able to be used with the xbox 360.
no, because it has a 15pin (joystick/MIDI) connector and it would need a USB.
Aug 13, 2010 | Microsoft SideWinder Force Feedback Wheel...
SideWinder Force Feedback 2 Joystick: need new drivers for vist...
For Windows XP , Vista and windows 7 it dont need drivers windows has them built in.
May 17, 2010 | Microsoft SideWinder Force Feedback 2...
Microsoft Sidewinder Force Feedback Pro 2 Drivers
You should be able to download them from the Microsoft web site.
Jun 15, 2009 | Microsoft SideWinder Force Feedback Pro...
My sidewiner worked fine with xp now new computer
You need the USB adapter if you want to use it in Vista. They are very hard to come by, as most of them don't seem to be compatible with any of the Sidewinder products. This is your only option and not guaranteed. The adapters are about £10.
Apr 05, 2009 | Microsoft SideWinder Force Feedback Pro...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 25, 2009 | Microsoft SideWinder Force Feedback Wheel...
Microsoft's Sidewinder Force Feedback Pro Driver
Sorry to report that there is no driver for this stick that will allow the feedback to work with Win XP. I wanted to cry when I first found this out. I've been searching since the mid 90's for a work around for this. We can send a man to the moon and back on less than 1 meg of ram. But someone can not get this stick to work properly with Win XP?
That REALLY SUCKS!!!
Dec 28, 2007 | Microsoft SideWinder Force Feedback Pro...
Microsoft SideWinder Force Feedback Wheel Wheel And Pedals Set Logo
264 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
