Question about RCA P61960 61" Rear Projection Television
GUIDE POST IS NOT DOWN LOADING TV STATION INFORMATION. NEEDS TO BE RESET. HELP WHAT ARE THE CODES
  • 42 Answers
Get the phone number from RCA.com and they will assist you. The guide is free for life of the set. That is what I did.
Posted on Oct 11, 2009
Says it requires 24 hrs time to program channels by zipcode 91042. Is this the case??
if you are programming a TV Guide type function yes.
The info is downloaded twice daily, around 2:10 pm EST and 2:10 am EST from your local PBS station.
The TV will wait for that down load before it gives any info in the TV GUIDE.
Apr 12, 2011 | Televison & Video
TV guide abruptly stopped receiving information
Off-Air reception (Antenna) of TV Guide comes from a supplier called Rovi (formally known as Macrovision, Gemstar). They have supplied your local CBS affiliate with a TV Guide application known as SCTE 127 or VBI in MPEG. Follow these steps until you have found a solution to the TV Guide - No Information Available.
1. Check to see if your local CBS station is coming in clearly not tiling.
2. Reset your TV Guide through your TV Guide Menu, for more information copy and paste the link below. (What usually works for me is setting up the guide by putting in 99999 for the zip code then answer all other questions. After it says your TV will receive the guide in 24 hours then setup the guide as you normally would with your zip code).
http://www.rovicorp.com/support/13094.htm?link_id=topnav
3. Contact your local CBS affiliate engineer and see if they are having problems with the TV Guide transport stream i.e. SCTE 127 or VBI in MPEG
FYI if you get your service from a Cable TV company they will have to pass this information through their system commonly referred to as Passing PIDS.
Feb 08, 2010 | LG 50PB4D 50 in. Plasma HDTV
Guide Plus not working
Guide Plus on TV is most likely a cable TV feature. If so, it would not be available from a broadcast antenna. Try checking the web sites for the TV stations you watch; most likely any stations with web sites would provide their schedules there.
Jul 10, 2017 | Televison & Video
Installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Have Warning message on DVD 'Your Guide Plus has not received TV Listings. Check your host channel.' What do I do?
Symptoms / Customer Description
TV Guide issues.
Example:
1. Not getting the correct info, or no information.
2. TV Guide giving double channels.
3. TV Guide grid comes up but no information.
[Primary Symptom Code: 118X ]
Solution
TV Guide information comes from the Host Station.
1. If no information on some channels or incorrect information not TV issue, but station not giving any information or incorrect information.
2. If grid comes up, but no TV Guide Info could be
siginal issue.
3. Double stations showing up. Unfortunately double listing is the way it's going to be. They have to send out all possible OTA listings for the area. You can hide the channels that you are not getting.
For these type of issues
Please have the customer call our Customer Support Line 800-222-7669
Our Call Center Rep. will fill out an investigation form with data pulled from the TV. These reports will be sent to Gem Star for their investigation, and the Call Center will get
back to the customer.
Apr 14, 2009 | Televison & Video
Guide Plus crashing
This problem is possibly a failure on you digital main pcb. Hoping its not hardware, best thing is to try to totally reset the guide plus. Go into the guide plus menu and find the setting to reset or restart setup. If this does not solve you issue, try hard booting the tv (unplug for 2 minutes) and try again. In quite a few cases, the manufacturer of the tv will have a software upgrade that may fix guide plus issues. Contact your manufacturer for that information
Dec 07, 2008 | Televison & Video
Tv won't work
I downloaded this off of Wikipedia. You are not the only person having the problem with the switch to digital television. The complaints are nationwide. the old TV Guide Plus has gone away for many viewers and soon for all viewers as the transition to DTV gets nearer. If you are using an antenna be sure to get the digital converter. They are practically free with a government sponsored coupon.
Digital television
The new service, launched in the United States in 2006, is entirely digital, using the ATSC digital television standard. While this will significantly improve the service, older systems will no longer be able to download listings once analog shutdown is done in early 2009.
It should be noted that the Program and System Information Protocol (PSIP) within the ATSC standard already allows for each station to send out its own EPG information, and in the U.S. the FCC in fact requires stations to do so for OTA (but not cable, unless they are rebroadcasting an OTA station that provides the PSIP data). However, actual implementation is rather spotty, and usually very minimal -- stations often don't have full descriptions (or even correct information) on the current show, much less the next 3 hours required of them, or the 16 days worth of guide information that can be transmitted. Additionally, ATSC tuners are not required to even show the EPG, only the very limited information for the current show on the current channel.
While the TV Guide service also requires software in the TV or other device, and licensing fees or royalties to be paid to Gemstar TV Guide, it also offers a more complete solution for broadcast television, more like digital satellite or digital cable.
Nov 28, 2008 | RCA 20F420T 20" TV
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
Channel Changing Problem
You have to go through the set up guide and reset the information you put in. It may have changed. Afterwards you must run through the auto program. This is a common problem i find with customers.
C-Dog
Feb 10, 2008 | RCA F27442 27" TV
What do i do about the v guide & how can i get it off??
MY TV BRAND NAME IS APEX MODEL # APT2702 & I HAVE THIS BLOCK THAT COMES UP WHENEVER YOU TRY TO LOOK AT CARTOONS ON ANY STATION. IT READS AS FOLLOW>>>>BLOCK DUE TO V GUIDE , RATING TV - Y 7-FV. PLEASE HELP ME GET THIS OFF MY TV !!!
Nov 24, 2007 | One For All URC4110 Remote Control
RCA P61960 61" Rear Projection Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
