Question about T-Mobile Sidekick II
Battery how do i fet to the battery
  • spice1 Dec 16, 2007
    how do i ge to the battery
    President:
  • 625 Answers
Http://people.hamilton.edu/praffert/sidekickdissected/skii/
The Sidekick II battery isn't meant to be replaceable. But you can get to it and replace it , it just takes some work!
Posted on Dec 16, 2007
Order of fets in alpine mrv-f400 amp
Its likely those FETS were not designed to be used in that amplifier configuration.
Jul 06, 2016 | Alpine Car Audio & Video
The drill suddenly just stopped working in the middle of the job - the battery is good but it doesn't seem to be getting any juice the worklight will not even come on.
If you can to take apart the drills, put the battery directly to the motor. If it is turning the , probably the switch is faulty. If it is a controlable speed drill, check the FET transistor. I recently replaced the FET in a Ryobi drill. Cost $5 and workin glik ebrand new.
Feb 11, 2015 | Dewalt 18v Cordless Hammerdrill Dcd970
NO SIGNAL FROM EXT ANT JACK
This particular model is known to be prone to static electricity.
You may try first to reset the radio by taking all the power sources off, including AC power, the D batteries, and the AA batteries. Leave it without any power for a day (at least 12 hours, but 24 hours would be better).
This would cause a processor reset. Plug the power sources after 24 hours and check it out.
If that doesn't bring it back to life, then you may have to open it and do some more involved work (if you are handy with soldering and replacing electronic parts).
Usually the sensitive part that gets fried by static electricity and causes your issue is the Q1 transistor, which is a field effect transistor (FET).
Most likely your FET Q1 is a Sony product which maybe labeled as 2SK152. It's out of production, but you may find it at some major electronics outlets, such as Mouser Electronics.
There should be some equivalent FET out somewhere (RadioShack, perhaps?), if this particular one is not found.
Replacing the FET should be an easy job after you have opened the cover (5 screws), and unscrewed the board.
Just be careful not to cause further damage by static electricity from your body (wear a grounded static discharge strap), and be very careful handling the board.
Best of luck, and hopefully you will comment here if this has helped you resolve this issue.
Sep 14, 2014 | Audio Players & Recorders
Scosche EFX work with MOS-FET Amplifiers
CAN YOU E-MAIL ME THE MANUALS FOR THE VOLFENHAG ZX 7150 AND THE ZX 7170 MY E-MAIL IS smas5305@yahoo.com thank you Thomas Anderson
Mar 22, 2010 | Scosche Industries EFX Amplifier Wiring...
Map light fuse on 2008 f 350????
The interior map lamps are powered buy the battery saver relay ( non serviceable relay ) Which is powered by Fuse #25 ( cab fuse panel ).
This is for the engine compartment and illuminated vanity lamps, as well as the map lights.
The FET ( Field-Effect Transistor ) shows the fuse #9 also on it. ( marked interior lighting ), which power the interior lamps ( door / switch ).
Could be a few things if both those fuses are OK.
1. The map / interior lamp combos are usually dual element bulbs, which means if the interior lamps ( door or dimer switch on headlamp panel ) are OK, it could still be a burn out bulb.
2. The FET is having an issue from a dead short ( blown bulb or dead short to ground ). Until the short is correct, the FET will not turn back on.
Start with checking Fuse #9 ( marked as Fuse #8 in the diagram, but that shows headlamp ), which is to the interior lamps, and drives 1 side of the FET.
Jan 07, 2010 | 2004 Ford F150
FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Replacement fet
http://www.mcmelectronics.com/product/483513047059 But this is a transistor NPN and a small one at that for only $1.39. A FET costs about $35.00. 9322 121 46687 is the power FET for that set. Location #7301 Description STW13NB60. http://www.partstore.com/Part/Royal%20Philips%20Electronics/Philips/932212146687.aspx IS one place, or Google your part# and see what comes up. Hope you find what you need. Good-Luck. Let me know if you need something else.
Dec 08, 2008 | Philips Magnavox 51MP392H Rear Projection...
Battery drill part
cep6060r or irf540 google em
Jun 21, 2008 | Dryers
T-Mobile Sidekick II Logo
27 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
