Question about Dryers
Kenmore front load dryer
Brownish stains are left on dried clothes.  Brown (rust or dye) can be wiped off the surface just inside the door at the interface of the drum and the body of the dryer.
    Scholar:
  • 146 Answers
Replace your inner door bearing. It is felt and sometimes as it wears it will cause a brown discoloration. Also when you check the drum make sure that is isn't rusting also. You will want to change the inner tub ring also. Depending on the age of the dryer you might want to change the belt, rollers, and idler pulley also. You change all of this from the front. 1st take the 2 screws out of the top where the filter is located. Then pull the top forward and up and it will pop up. Then there will be 2 - 5/16 head screws on each side of the front panel. You will see them about 2 to 3 inches down on each side in the front. If there is not a front kick panel after the 2 screws are out just pull the front panel up and out. Then you will see everything I am talking about and it should be fairly easy from there.
Posted on Dec 21, 2007
The Dryer is Dead. It will not make a sound when the start button is pushed
Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or OK like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle approx between 120 degrees and 160 degrees ( without clothes ). Check that the drum seals are not worn out.
Be careful in using laundry products not to spill them on the exterior surface of any washer or dryer. Wipe up any spills promptly with a damp soft cloth or paper towel. Most exteriors are painted synthetic enamel, which can be damaged or removed by chlorine bleach, ammonia, solvents or other chemicals often used in laundering and stain removal. Do not use dryer top as a work-top for stain removal unless it is protected by a heavy plastic cover, or for rust removal. Use the sink instead and follow remover product label directions exactly, including flushing the sink with cold water.
Do not spray per-wash stain removers on clothing on top of the dryer unless the top is protected completely; this may corrode plastic control parts as well as paint.
Clean lint filter after each load for efficient drying. If the load is loaded with lint, clean the filter part-way through the drying cycle also. Clean out the exhaust vent system at least once a year, and be sure it is not clogged at any time. NEVER vent a dryer into the house; vent to the outside
If crayon gets into the dryer and melts onto the drum, remove as much as possible with non-flammable household cleaner. (READ LABEL TO BE SURE.) A flammable cleaner could cause a fire in the dryer. Apply cleaner to a sponge or cloth and the wipe interior. Do NOT spray or pour on the interior; it might get down inside the dryer. Wipe off with rags or paper towels. Then tumble old rags to remove any residue left, until no more comes off. A colored stain may remain on the drum.
If a drum is spotted by starched or tinted articles, wipe the interior with a cloth moistened with a diluted bleach solution. Use a sponge or clean cloth, dipped in suds, to remove the bleach solution from the drum. Rinse well and dry.
If the dryer is used to dry laundered clothing, such as children snow pants between outings, wipe the drum with suds and rinse. This will remove any dirt before clean laundry is placed into the machine.
Wipe the door opening occasionally. Clean the exterior with suds and rinse. To protect the finish, polish with an appliance wax.
A case of white clothes coming out of a dryer blue: New jeans had been washed and then dried in that dryer just before. Sometimes dye will come off new blue jeans and dry on the inside of the dryer drum, and then transfer to the next batch of wet clothes put inside. It's good to check the dryer drum after a load of brand new jeans. If it is dye coated, clean the inside with soapy water until no color comes off on the cleaning cloth. Wipe off all soapy residue with a clean wet cloth.
Check with your state or city to see if you need a permit to work on your gas dryer before doing any repairs. The first thing you need to do when your GE-HP gas dryer is not heating, is to check to see if your dryer ignite is glowing or not.
please comment on these solution by staying now helpful
If the ignite glows, the problem could be the gas valve, the coils or the gas supply to the dryer.
If the ignite doesn't glow, then you need to check the following parts.
The igniter:
The igniter is a resistor made of ceramic and other materials that will get red hot when electricity passes through it.
The job of the igniter is to open the contacts on the flame sensor and ignite the gas. A bad igniter could be the reason why your GE-HP gas dryer is not heating.
The flame sensor:
The flame sensor is located on the combustion chamber, the job of the flame sensor is to open the gas valve and shut off the igniter. A bad flame sensor will cause the dryer not to heat.
The timer:
The timer is a distribution center where the electricity is directed to the different electric parts in the dryer.
The mayor problem you will find inside of the timer are burnt contacts.
When the contacts are burnt, there is no way for the electricity to reach the intended parts. Contact B & A have to be close in order for the electricity to travel to the temperature switch.
The temperature switch:
This switch is another distribution control. It take electricity from the timer and send it to the selected parts on the thermostats. If your GE-HP dryer is not heating, this is one of the parts you need to check.
The thermostats:
There are three different thermostats in most dryers. From the temperature switch electricity has to pass trough the safety thermo left, the drum outlet thermostat, the control inlet thermostat, and to the heating elements.
A bad thermostat could be the reason why your GE-HP gas dryer is not heating.
The motor switch:
The motor switch has two contacts that allows the heating elements to be turned on, only when the motor is running..
Dec 21, 2010 | General Electric DBSR463GGWW Gas Dryer
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Brown streaks
Remove the water supply hoses and check the small screens inside the ports on the water inlet valve. Make sure they are clear of rust and debris. A common problem is the screens getting rusty and putting the iron oxide into the wash water causing brown stains or streaks to get on clothing and sometimes leaving a brown ring around the tub. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown stains on white clothes in front loading washer
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Clothes dryer
It could be rust stains coming from the tub of the dryer during the drying cycle. The only concern is that rust stains are usually brown streaks on the clothes. I'd check the to make sure there are no rust stains on the tub, check the seal of the door to make sure its still in good condition. The last possibilty could be a good cleaning of the dryer (removing lint from the lint screen compartment and the tub of the dryer).
A schematic of your dryer can be found on www3.sears.com and should show how to get into your lint screen compartment and your tub.
Feb 07, 2008 | Zanussi TD4100W Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
The 417 dryers have two seals on the front panel, the top seal has drum glides which wear down over time. Because the drum rests on those glides, when it wears down it leaves a gap between the drum and the seal, clothes will drag in that gap and come out with rust and/or seal adhesive stains. Try replacing the top and lower seals, this works most of the time...sometimes though, if left unattended long enough, the lack of support from the front glides causes too much strain on the rear drum bearing, and even after replacing the seals clothes may still catch, although the brown spotting will stop for awhile. You can feel the gap if you run your hand along the inside of the drum at the seal point.
Dec 29, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
185 people viewed this question
Top Dryers Experts
