FixYa.com
Tags:
Wireless Adapters
Generic problem for all Wireless Adapters
Wireless Drivers (by 4 users)
posted by grassie on Dec 16, 2007
Do you know were we can get wireless interfaces for the atheros chip sets. We are using fedora and/or Redhat and would like to use 8 wirelss cards per interface but we are struggling to get the wireless interface done.
Do you know where can we buy beg steel this ?
Comment by grassie, posted on Dec 18, 2007
No we are not interested in the source only in the working module.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by tuxs99, posted on Jun 12, 2008
i need driver for asus wireless 802.11
Comment by Duke1954, posted on May 12, 2008
cannot find driver download on the internet?
Comment by Guest, posted on Dec 24, 2007
i can not find drivers..i have lost disc..i reformatted my PC and can not find driver for
Foxconn WLL-3350 (WLL3350) 802.11g/b Wireless Adapter
Best Solution
posted on Dec 16, 2007
Helpful (85)
pasha19
Rank:Wiz Wiz
Rating: 85%, 509 votes
Is this what you are looking for?
http://sourceforge.net/projects/madwifi/
Comment by pasha19, posted on Dec 18, 2007
Did you consider using form length?
Note working by lines and not inches is probably preferable because you have control to the line width and not the inch.
If you are running 8 lines per inch on a default 11 inch form and form feed is taking you too far -- 88 lines. 9 inches is 72 lines. After opening the printer issue the form feed to alter the number of lines to 72. Adjust the number as necessary until it is right
ESC C 72
For 6 lines per inch or 66 lines on an 11 inch page. 9 inches would be 54 lines
ESC C 54
Then the page should not overshoot the mark and you need not back up
Sorry wrong issue on the previous post.
You need to access the SVN directory to get the source
more later
Debian source
http://packages.qa.debian.org/m/madwifi.html
Points to Madwifi.org which is where you can probably get access to the instructions for accessing the source from sourceforge but I have been unable to access the site. I have found both Fedora and RedHat links pointing to madwifi.org too.
The code tab of the original link has the information to access the code using a cvs client.
manually you can access the CVS from the Browse CVS Repository link.
Rating Locked! (?) grassie has rated this solution as Helpful
Solution #2
posted on Jul 05, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
viewsonic wusb100 work (ndiswrapper)
I found google
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
viewsonic wusb100 work (hdiswrapper)
I found google
This Problem Also Relates To: HP (J7801A) Wireless Adapter HP (325526-001) (325526001) 802.11g/b Wireless Adapter 3Com (3CRUSB10075) 802.11g/b Wireless Adapter 3Com (3CRWB6096B) Bluetooth Wireless Adapter 3Com (01N0505) Wireless Adapter 3Com (030020006) Wireless Adapter Panasonic (ET-CDWL1) 802.11b Wireless Adapter
Can you Help with these Wireless Adapters problems?
Intel PRO/Wireless 2200BG 802.11g/b
Atheros AR5001A
D-Link 802.11g Wireless Router WBR-1310...
when i hook up ther
when i hook up ther router my... Answer This...
Symbol Spectrum24 Wireless Neworker (LA-4137)
No Light
I just setup my desktop to have... Answer This...
Belkin F5D7330 802.11g/b Wireless Adapter
Similar Install Problem
I'm having the same problem... Answer This...
Motorola DC800 Wireless Adapter
Using it as a receiver
I have my DC800 connected to my... Answer This...
Repair Service
Find Wireless Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
