Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
After about 21/2 years, our refrigerator stopped working, everything had thawed out overnight. The control panel allows me to change the temperature in the freezer and refrig. The fan is working because I could feel air flow from the cooling vents. I called Kitchenaid and they are sending out a repairman, but will not be able to start the repair for 2 days. What should I do or try?
I had the same problem, the only good part is that I went to get ice and got a cup full of ice and water... I realized the fridge was failing, so I transferred all my food to my spare fridge. I only had it because it failed a few months ago, and it took 2 weeks to get the part (control unit in the top of the fridge). This time, it was the other control unit in the rear of the unit. This one controls the condenser/evaporator, etc. The repair man said it was both the ECU and the Inverter box. He showed me that it was burned (brown discoloration of the Inverter). He wanted over 500 to replace these parts. I just ordered the parts from appliancezone.net for $230. But I am handy enough to install them. If you are not, please let the repair man do it... otherwise, if you are, or you have a friend that can... it is VERY easy. The part numbers are 2307028 ECU and W10133449 Inverter Box (This is the new model that replaces 2304175)
Posted on Sep 26, 2009
4 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Posted on Apr 26, 2009
  • 46 Answers
SOURCE: Kitchenaid refrig KSRS25ILBL03 will not maintain
if this only last for a shot time its just in defrost
Posted on Jun 27, 2009
heatman101
  • 43501 Answers
SOURCE: FREEZER & REFRIG STOP WORKING
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 25, 2011
Hello, We have a Whirlpool Gold bottom freezer
I don't know about Whirlpool refrigerator freezers, but my Amana has a temperature control in the freezer that regulates the overall cooling, and then the control in the refrigerator compartment controls how much of the total cooling is sent to the refrigerator section. My advice would be to lower the temperature setting of the freezer, and see if the temperature lowers in the refrigerator as well. Also, you can go to the Whirlpool website and they can help you further.
Aug 02, 2013 | Refrigerators
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
There is a drain that carries water from the freezer to a drain pan in the base of the fridge. It has plugged preventing water from draining and in turn the water has froze blocking the flow of air to the fridge. First you must find the drain line in the rear of the fridge and unplug it as well as thaw the fridge out overnight to allow the water to drain... be patient as there will be a lot of ice to be thawed out, let me know if it works! good luck!
Jul 20, 2011 | Kenmore Top Freezer Refrigerator
Refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
Jun 24, 2009 | Frigidaire FRT17G4B Top Freezer...
Kitchen flooded from whole freezer thawing out overnight..
hi, this is a control panel board failure. this will unfortunately have to be repaired by the whirlpool tech. the main sign for control panel failure is the uneven temperature that you are experiencing in the refrigerator.the control panel has lost its ability to maintain proper temperature. i would take a look at the thermostat as well. it may need to be replacing.
Mar 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Frig working, freezer stops working, then starts working again
The computer control circuit board was found to have a burned out circuit. The board is on the lower back side behind a panel, easy to replace. Just need the proper model number to order the board.
Sep 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Dec 02, 2007 | Refrigerators
Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
199 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
