Question about JBL Control 23 Speaker
Fender reverb mod both channels
I want to mod my fender normal channel to have reverb I put a jumper from pin 6 on the first pre amp tube to pin 6 on the second preamp tube , that worked but I lost a lot of power on my reverb chanel so I undid it.I tryed the Dan torres method and the amp sqealed it did not like that . Any suggestions?
  • 1 more comment
  • guitar77 Dec 16, 2007
    It is a fender twin reverb with a master volume. The closest schematic I have found is the fender twin reverb 100 watt rms. It looks really close to the ab763.
  • guitar77 Dec 24, 2007
    I did go to that site the mod was not explained to well and his self drawn up schematic was poor I dont want to fry anything in the amp I just rebuilt it and I'm still just learning thanks
    can someone give me a layout or descent drawing of the mod then I think I'll be able to pull it off. I'm still learning and a lot of this is confuseing thank you
Go to http://www.silvertoneamps.com/micKfender/Fender-Reverb-Both-Channels.html
there is info on this mod. heed the warnings of hot rod activities!!
There is a solution to your misguided nods you mentioned earlier.
Posted on Dec 24, 2007
This is a pretty simple mod which I have performed 3 times now with great success and even did it last night to my own super reverb. The mod is detailed and well explained in the latest edition of the tube Amp Book by Aspen Pittman of Groove Tubes!
Posted on Dec 05, 2008
1st step the (2) 220k resistors going to the phase inverter 1 goes to normal channel the other to the reverb vibrato channel diconect the wir going to the normal channel connect that wire to the 3.3m reverb resistor it probably hase a 10pF cap in parellel with it 2nd step now connect the 220k resistor on the leg that you diconected the wire from done you should now have reverb on both channels also made the amp seem a little loader too hope this helps you can contact me at basementamps@gmail.com for further info just put reverb help in the subject line so i know. Mike
Posted on Aug 06, 2008
Where do I test for break in the Mx15r input cuircut if its not sending
The MX15R has a clean and overdrive channel with a common input. The reverb is between these input channels and the power amplifier. The common link between the two, is the input jack and selector switch which chooses which pre-amp section to use. I would check out this switch and jack as most likely, one of the other is open.
Jun 23, 2017 | AMP Music
I just bought mesa express 5 50 amp. After a couple of weeks the reverb control malfunctioned - no reverb, and the overall tonal quality drops. Is this a common problem? is it the tube?
Quite likely a valve. The only valve unique to reverb is V5. Clearly labled on the amp. Or check your manual. It's a 12AX7. You can't really swap it with another because they are all common to both channels. Just buy another - not expensive. If you have not changed valves before:
1. power off
2. let valves cool
3. identify V5
5. note the orientation by pin layout on your new valve.
6. remove valve (might have to wiggle gently)
7. do not force in new valve - pay close attention to orientation.
If it is not a valve, then it gets complicated, take it to a tech
Aug 22, 2013 | Mesa Boogie Mesa EXpress 5:50 2x12 Guitar...
My new Bugera 333 212 combo has a weird "ringing" noise on the crunch channel. The noise can be heard on other channels too, but it is loudest on crunch. The noise is clearly mechanical, (it...
Microphonic tubes can be detected by tapping them lightly with a pencil. I cannot find if this uses a spring reverb, but if it does, vibrating the cabinet will get a clanky type sound from the reverb tank. This MAY use a digital reverb however which is immune to that. Next thing is to make sure your guitar can't "hear" the output sound of the amp because the strings can pick up the sound and resonate feeding back into the amp. You can detect if this is happening by quickly dampening the strings and see if ringing gooes away. You probably need 6 to 10 feet of clearance between the guitar and the amp OR put your body between the amp and the guitar. ALWAYS set sound level at safe levels. Get a sound meter and go no higher than 90 Db. I know a lot of near deaf musicians whose careers are near over because of hearing loss using too high level.
May 24, 2011 | Behringer Bugera 333212 120W 3 Channel...
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
I've told my Frontman 65r has a real reverb tank (accutronics). But it's almost imperceptible, even with the reverb knob at 10. Is that normal? Also, mid scoop for the drive channel and treble/bass for the...
The reverb should be quite strong. I would first look at the reverb volume pot R42 which is a 50K pot. I would also check the voltages on the test points near U4 (TLO-72 op amp tp13 and tp14) which amplifies the signal coming out of the box. It is possible the box has low power levels as well.
The problem is going to be around that section of the board if it isn't a dirty or dead(ish) pot.
The reverb should be noticeable enough to be annoying ;-]
Mar 18, 2011 | Fender Frontman 65R 65W 1x12 Guitar Combo...
I have a Fender 2x12 Hot Rod Deville. The clean channel seems to be working fine but the overdrive channel is not. I have to turn it up all the way in oder to get just a little bit of sound. So that...
For the Drive channel you need to use the Drive control AND the MASTER volume control. When the Drive channel is active, the Channel Indicator lamp should be RED indicating the Drive Channel is active. The Drive control knob is used to adjust the preamp volume and distortion level of the Drive Channel. This gives you a clue as to what to check if adjusting the controls doesn't work -- the preamp tubes. Having said that, ONLY try to check these tubes with the amp OFF! Never stick your hand up into the chassis of a live amp. It could be lethal. Your preamp tubes are the ones farthest from where the power cord enters the chassis. They have a rubber like stabilizer on them. They have a tendency to wiggle loose, which is part of the reason for the stabilizer. Again, if you're not familiar with the insides...stay out and get an amp tech to help you.
The Normal Channel only uses the Volume Control to adjust volume.
Feb 01, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Apr 24, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My Fender Blues Deville 212 has a very "ratty" tone on clean...
i am guessing on what the problem is , the post is very vague. i am guessing a channel switching issue. you need to check the "sugar cube" looking power resistors solder welds. they are probably cracked and arent making good contact. if you tap on the amp it will cut in and out, its probably these two resistors. they are usually 470ohm 5 watt cement resistors. what happens is they get real hot, and as they cool down they crack the little solder welds. i usually replace them with new and keep them floating up over the pcb to help them stay cool and off of the board to prevent further solder weld cracking, stock they are real close to the board. then put a little silicon under the resistor to hold it in place and to keep it still on the board. i just fixed a blues deluxe with this issue. while you are in there, cut out the resistor sitting right behind the reverb pot, this will make the reverb awesome. also solder the mid pot center leg to the mid pot leg that comes off of the bass pot leg to get better midrange control. very easy mods. check the master volume pot, is it a B100K? pull it and put an A250k in its place for better volume control. bias pots , etc. check my website yostamplifier.com.
Mar 05, 2010 | Fender Hot Rod Deluxe Guitar Combo...
No clean tone - no volume
First thing I'd check is if the valves / tubes are plugged in properly (it doesn't take much to loosen them) Unplug the amp then take out all of the valves and put them back in again.
If that doesn't work, try swapping the preamp valves (the little ones) around (let them cool down first) that'll tell you if one of them is worn.
Failing that I'd try cleaning the gain and volume pots with some switch cleaner, and if that didn't work I'd bite the bullet and buy a new set of valves.
Hope that helps
May 27, 2009 | Fender Hot Rod Deluxe Guitar Combo...
JBL Control 23 Speaker Logo
1,646 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
