Question about Video Cameras
Error Code on 7302 on JVC DV 500u Camcorder
I'm getting the error code 7302? Any solutions to repair it?
SOURCE: Problem with JVC Mini-DV Recorder - Model GR-DVL100
Hi KeeKee,
I have the same camera but I donot have the driver to download video onto computer. I use window XP. Can you help if you have the driver?
Thank you
Posted on Dec 27, 2007
kala
  • 156 Answers
SOURCE: please help me to get USB DRIVER
Please try to enter in JVC internet site and put your model number to get driver.
Posted on Jan 01, 2008
ctf1800
  • 4402 Answers
SOURCE: error code EO3
· http://www.camcorderinfo.com/bbs/index.php
· JVC camcorders
· Tap o the side to fix your problems
-only, only, only use the more expensive JVC tapes. They keep their tension far better than cheaper brands. Also, they won't rub off their oxide coatings on the heads as easily, avoiding the 'clogging' of the heads (which thereby requires constant cleaning-further damaging the heads).
-when and if you do get E- errors do a complete rewind or fast forward to the end of the tape in order to pull out tape slack. Then remove battery and tape for a while. If still screwed, then yes, sharply tap (not hard!) on the closed tape door. That may reposition those tiny switches that I mentioned earlier and get you going again.
-NEVER, EVER, EVER, leave tapes in the machine when not in use....it creates problems for the heads and the mechanisms.
-Don't leave the battery on the camera when not in use for extended periods of time. It can create problems with respect to resetting the computer controlled logic.
-there are little switches and interlocks that provide electrical feedback about the mechanical status of things to the main processor of the camera (ie. tape/no tape in camera, door open/closed etc). Over time, the mechanics get out of adjustment because of usage, humidity and certainly rough handling. So: treat the mechanisms very, very, very delicately. Don't use/store the camera in humid conditions, hot conditions or very cold conditions. Certainly don't leave it in your car---ever!
-get the camera "cleaned and ajusted" regularly to avoid these problems. (I know...more $$$$)
· -I keep bags of dessicant in an insulated camera bag with the camera to maintain dryness and optimal temperatures during storage.
Posted on Feb 07, 2008
ctf1800
  • 4402 Answers
SOURCE: JVC GR-D33U ERROR CODE EO4
· JVC camcorders
Posted on Feb 11, 2008
kala
  • 156 Answers
SOURCE: JVC GR-D250 Mini DV Digital Camcorder Authorised service center in pune india
This model is not supporting with pc when you play cassette only it is supporting with memory stick
Posted on Feb 28, 2008
My camcorder is stuck in safe mode
I need to know more details about your problem, error code follows numeric code. Such as 01, 02, 03 etc. you need to consult an expert. Don't force the mechanism for it will cost you more to repair.
Feb 27, 2010 | JVC GR-DVL500 Mini DV Digital Camcorder
Keep getting 0E4 CODE ????? ON JVC MINI DV
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA.
Sep 08, 2009 | JVC GR-DVL520 Mini DV Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
THE LENS CAP!!!!!
BAD CCD ! FREE REPAIRS thru JVC
see link
http://www.jvc.co.uk/template.php?page=100102
Dec 23, 2008 | JVC Cybercam GR-DV500US Mini DV Digital...
SAFEGUARD MODE ERROR CODE E06
Why not do what the manual says ? They're printed to assist you.
Jul 14, 2017 | JVC GR-D201U Mini DV Digital Camcorder
JVC GR-D250 Mini DV Digital... Problem
There is any error code displying on the lcd screen?
Feb 28, 2008 | JVC GR-D250 Mini DV Digital Camcorder
CAMCORDER ISSUES
There Should be error code start with.E-
Jan 05, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
71 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
