Question about Nokia N79 Cellular Phone
Camera recording is hanging while record what to do?
Camera recording is hanging while record what should i do i have updated version v.30.xx.xx
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
Remote control won't work for DVD Recorder
Hi abrooks...Clicking on the following URL will take you directly to the Acceptance Page that will allow you to download the proper update applicable to your Unit and Issue. Applying this update to your player will provide your resolution....good luck my friend http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloadsTermsConditions?storeId=15001&fileName=DMR-ES25/DMR-ES25.EXE The following are details of the file that you will be downloading; Version: IR-01 Last Updated: 5/2/2006 Description: This version restores IR Remote operation if the unit has stopped responding. After this update has been installed, please be sure to disconnect the unit from AC power for a minimum of 30 seconds.
Jul 26, 2007 | Panasonic DMR-ES25 DVD Recorder
HI My LG V181 DVD Player / VCR Combo will not play divx. What can I do? Can I upgrade the software? Mark
Divx compatibility with this player is limited as follows; available resolution size of Divx is under
720x576 pixel - file name Divx subtitle is avail by 56 characters - if number of the screen is over 30/sec the unit may not operate norm - playable Divx file avi,mpg. .mpeg - playable codec format
DIVX3.xx - DIVX4.xx - DIVX5xx -XDIV - MP43 - 31VX - if the video and audio structure of recorded
file is not interleaved, either video or audio is outputted.- if the fie is rec GMC the unit supports only
1 point of the record level - may be helpful!
Feb 06, 2011 | LG V181 DVD Player/VCR
I use spypen 16gb i required anyka usb web camera driver & time.txt for change time dt. for my spy pen
How To Update Time Automatically of Spy Pen Camera
1)
Connect the camera to computer via USB cable
2)
Download GetSysTime at http://diganet.net/downloads.html
3)
Click GetSysTime.exe to update the date and time, the
time of the camera will synchronize with the time of computer after restart of
camera upon reconnecting.
Nov 27, 2010 | Computers & Internet
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
My Panasonic DMR-EX85 is locked into region 2 Can you help to to make is Region Free please Thank you Roger
TRY DMR-E85 DVD Recorder Firmware Update
Version DL-106
  • Compatible Models DMR-E85HS
    2. Improves playability of discs with high reflection detected.
    3. Improves playability of discs with fingerprints.
    4. Improves disc playability corresponding to CPRM.
    5. Improves playability of DVD-RAM x16 discs
  • http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-E85HS.D#ts
    Oct 26, 2009 | Panasonic DMR-E85H DVD Recorder
    I need driver for Windows Xp for RR_US395
    The software you are requesting is available directly from Panasonic.
    http://panasonic.jp/support/global/cs/soft/download/voice_editing11.html
    You will need the serial number located underneath the battery of the unit in order to download the software. If you wish to keep your settings in the unit, do not leave the battery disconnected for longer than 30 seconds. Also, make sure you completely uninstall any previous versions of the software. The updated version will not install properly with existing versions.
    Jun 08, 2009 | Panasonic RR-US395 Digital Voice Recorder
    DSS player v. 7 will not install on Vista64. Install program hangs at green screen.
    Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
    Above is the update that makes the software compatible with Vista and then there is an update from the olympusamerica website that also needs to be run as well.
    http://olympusamerica.com/cpg_section/software_results.asp?id=1276&os=w
    This shoiuld correct the issue with the player software functioning properly.
    May 03, 2009 | Olympus DS-30 Digital Voice Recorder
    Mac OS 10.4.11 does not recognize the Zoom H4 recorder
    Mac OS 10.4 and higher require the Zoom H4 to be upgraded.
    Go to  http://www.zoom.co.jp/english/download/software/h4.php#a  and choose the download to version 2.20 that applies to you. The instructions are there, but it is a little tricky. You must download the upgrade to your computer and then transfer it to your Zoom SD card.  To do that you need an SD card reader.  I used my digital camera. I took the SD card out of the zoom and put it in the digital camera. I Plugged the camera into the computer and when the SD card icon appeared on the desktop I dragged the "System Bin" file from the download to the zoom folder.  The rest of their instructions were pretty good.   Good Luck.
    Sep 12, 2008 | Zoom H4 Handy Recorder
    Nokia N79 Cellular Phone Logo
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
