Question about Dynasty DGRSC 30 Gas Kitchen Range
The broiler doesn't work.
I've tried turning on the broiler and lighting it with the ligher, and the igniter doesn't do anything either. It's a natural gas version 30". Sorry to be so vague, but I don't know much about this stuff. any help would be greatly appreciated. It's a 400.00 service call to have someone come out. I would much perfer to resolve this issue myself.
  • Mark Lee Sep 24, 2009
    It doesn't have a pilot persay, it's an electic filliment, that is about an inch long, half an inch wide, and about a quarter of an inch think. This filliment sticks out over the ceramic serface (where the heat is suppose to come from). The filliment doesn't get warm at all.
    So if I understand you, there is a relay, or safety apporatus that prevents gas from flowing, so I understand, it could be either the safety component or the ignitor? If the ignitor has failed, then the safety shut off would not allow gas to flow. Right?
  • 1,986 Answers
There is usually some kind of heat or flame sensing safety on gas appliances. If the devices senses that the flame, starter, or pilor light has gone out, it will not allow the flow of gas. This is to prevent the appliance for just spewing gas into the room if it does not light. I'm guessing that this sensor may have gone bad.
Posted on Sep 24, 2009
  • super_guy Sep 24, 2009
    That is correct
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler works Bake Oven doesn
The first thing to check is the oven igniter, check for spilled foods on igniter and clean if necessary
Dec 12, 2009 | Televison & Video
Oven will not light but broiler works
More than likely the igniter for the bake manifold has become weak over time and now needs to be replaced. Each burner manifold in the oven has a separate igniter. That's why your broiler still works. Due to the frequency of use, the bake igniter wears out faster and may require replacement more often. The following link explains a little theory on how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Hotpoint RGB745 Gas Kitchen Range
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one...
first I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Aug 15, 2008 | Maytag CWG3100A Gas Single Oven
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Dynasty DGRSC 30 Gas Kitchen Range Logo
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
