Question about Philips 42PFP5332D 42 in. Plasma Television
New tv We plugged on our new Philips 42 inch plasma tv and the screen worked for a little bit then once we turned the tv off the screen wasnt as clear and things are distorted. is there some type of set up that is needed between teh tv and satelite?
  • 138 Answers
You can go into the menu and adjust the picture setting. If that does not fix the iss and the set is under a year old then it will still be in warranty. Contact Philips at 1-88- 744-5477 and have them do the repairs under warranty. Don't do it your self because that will void your warranty.
Posted on Aug 20, 2008
MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Philips Televison & Video
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Jun 18, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Just bought a philips 42 inch ambilight plasma t.v,and didnt know the plastic screening round the out side is supposed to light up, how do i go about setting this up?
Bottom left button on your remote should turn the light on and off. if this doesn't work sort through the options on remote and select ambiant light functions
Mar 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
Green screen
I am a TV repair technician and what you are experiencing with your plasma and PS3 is a HDMI compatibility problem. The Philips plasma and the PS3 electronic handshaking (EDID) are not right. This happens alot with an older version of HDMI like 1.1(Philips Plasma) and a newer version of HDMI 1.3 (PS3). A tv firmware or PS3 firmware update will not resolve the problem. I would recommend using the HD component video cables and that should work just fine for playing High Definition BluRay movies.
Oct 05, 2008 | Philips 42PF9966 42 in. HD-Ready Plasma...
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips Plasma Flashing Red
every plasma tv ive come across with this symptom eneded up beeing a new panel. what i do is replace the x and y sustain boards and if that dont work youll need a new panel.
Sep 08, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 42PFP5332D 42 in. Plasma Television Logo
138 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
