Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
Phone still on but the screen isnt
The screen is just blank but the actual phone still works i can hear the sound effects but cant see a thing!!!
Screen not working its blank
HI DEAR
CHECK WHEN YOU POWER ON THE PHONE DO YOU HEAR POWER ON SOUND OR CHECK IF YOU CAN RECIEVE CALLS WELL.IF BOTH ARE YES THEN THERE MIGHT BE A PROBLEM WITH LCD DISPLAY OR DISPLAY IC, BOTH CAN REPAIRED BY HARDWARE REPAIR PERSON. IF YOU CANT HEAR POWER ON SOUND AND CANT RECIEVE CALLS AS WELL THEN UPDATE THE THE PHONE FIRMWARE
Apr 06, 2012 | AT&T Quickfire Cell Phone
My phone is switching on ok and the screen is lighting up but nothing is happening.One minute it was working, the next it went blank. I have been told that it needs a new screen but I dont know why. It...
Hello
I suspect a flex problem
The flex is what connects the screen of the phone to the board of the phone.
what you are experiencing is common with all flip phones and slide phones, the more you flip and slide these type of phones,the flex gets weaker and that may be the cause of the blank screen
What you should do is;
Open your phone,you will see a plasticlike cable connecting your phone screen to the board of your phone(that is the flex)
Remove the flex and fix it back carefully, you should hear a click sound.
Close your phone and switch it on you wont have a blank screen anymore.
if you cant do this yourself,get a person with experience to do it for you
Thank you for visiting fixya
Mar 01, 2010 | Nokia 6270 Cellular Phone
THE SCREEN IS BLANK, I CAN'T TYPE ANYTHING. ACTUALLY NOTHING IS VISIBLE ON THE PHONE.
does the phone still have sound?? try checking, by calling 112 or operator, if it owrks and you hear sounds that imposes lcd problem, have it replaced by a service technician because doing it yourself could be tideous,
Dec 17, 2009 | Samsung: P520 Giorgio Armani Edition Cell...
Blank screen, cant hear anything on the ear piece!
replace the phone, that is symptomatic of a phone that has a compression crack, (sat down it was in the pocket, shut too tight, etc) There is no repair, but if you have the insurance it is covered as damage.
Aug 20, 2009 | Motorola Mobility RAZR V3
Helio Ocean..blank screen
I managed to fix mine! It takes some doing and is probably not for the faint hearted. You have to disassemble the Ocean from the battery side, removing the qwerty keyboard, to gain access to the slider assembly.
Disassemble the slider (pay attention to the spring!) and clean all contacts and make sure all of the flex cables are seated completely. Mine was working OK the qwerty way, but was blank and/or garbled the long way. Now it works great!
Sep 09, 2008 | Helio Ocean Cellular Phone
Blank white screen
when switched on the phone,my phone screen only show nokia and i want to turn off cant. how to solve this problem?
Feb 08, 2008 | Nokia N76 Cellular Phone
Unable to use my w900i's phone functions, can only listen to the mp3 player
When I try to charge my W900i the transfer files screen appears as if its connected to a USB device. When I connect it to a USB device I cannot seem to get the correct drivers installed to enable internet use through my phone. I also cannot save any new pictures taken with my camera as it's not saving them to the phone. When I check the memory it says that I have ample memory though...why is this? I connected my phone to my pc and it shows the phone memory but it doesn't connect to the PC suite. PLEASE HELP!
Marlon
Jan 26, 2008 | Sony Ericsson W900i Cellular Phone
BLANK
the problem of your phone is the flex cable, just go to your nearest repair phone shop if they have a spare of flex cable for your phone.
peace!
Nov 27, 2007 | LG PM-225 Cellular Phone
No sound whatsoever on LG KG800 Chocolate Phone
i got the same problem...what a POS phone, also sucks for text messaging. if you switch to speaker phone u can have your convo, but i have a loud car and cant hear speaker, need the earpiece, but its totally dead :(
Nov 21, 2007 | LG KG800 Cellular Phone
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
183 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
