Question about Sony FW900 24" CRT Monitor
Problem with FW900 with low resolution
I recently bought a 24 inch screen FW900. This screen works perfectly except for the lower resolution or with a frequency of 60Hz. With 60Hz and a frequency 640x480 or 800x600 I got no display(black screen). The monitor detects a signal at the input (I tested the two entries) but there is no display. It's embarrassing because at PC boot, i have no display entering the bios and the display is done only once into Windows. No display either the first launch of some games that are defaulted in low resolution and 60hz. With 72Hz and 1024x768, the display reappears. Has anyone had the same problem or idea of the origin of this problem? I tried with several different PC and still have the same problem. The tube is in perfect condition and when the screen is working the display is very very good. Thank you for your help.
SOURCE: Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Posted on Nov 11, 2007
Rifaa
  • 99 Answers
SOURCE: Monitor HZ problem
try booting in safe mode and reducing the resolution and the refresh rate to a value which the monitor can handle
Posted on Nov 08, 2008
SOURCE: black screen with message about no input signal
might be something wrong with your monitor's data cable
Posted on May 21, 2009
RescueTechLA
  • 2653 Answers
SOURCE: No picture, sound or menu on PS3
Try booting the PS3 with the hard drive removed from the drive bay ( on the side) you just remove the small plastic piece hidding it and remove one screw. It's easy. Let me know what happens. Also make sure you also plug in the original red white n yellow cables too to check if it's just an hdmi issue or system wide.
Posted on Nov 20, 2009
  • 1623 Answers
SOURCE: I can not change the
you need to change the res on the computer then it will change on the monitor
Posted on Apr 03, 2011
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
Oct 15, 2012 | Soyo Computers & Internet
Macbook and 24" display flicker when plugged in
MiniDisplay will probabely not support the Cinema's screen resolution...
Sep 05, 2012 | Apple LED Cinema Display 24 inch LCD...
I have a 24 "
First check to see if you have the correct graphic card drivers installed.
Then change the resolution. In some monitors, if the resolution is set too low, you get the condition you describe. The system thinks it's sending to a smaller monitor.
Jul 21, 2011 | AOC Monitor
Moniter screen not displaying anything except the resoluton is too high or oo low frequency not matched how solve these problem
does this happen right after you power up your computer? or after the windows loading screen? if after the windows loading screen, what you can do is to restart your computer. while booting up, press f8 repeatedly and select safe mode.
If you successfully logged in to safemode, you can lower down the resolution.
you can do that by Right cliking on the desktop, click on properties, then change the screen resolution to a lower one.
Hope that works.
Feb 06, 2011 | HP Pavilion a705w PC Desktop
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
We have just bought an LG 23 inch monitor. Everything okay on it except for the proper resolution. The monitor no. is W2343T. I have put the resolution of 1920 x 1080 and frequency of 60 hertz on it as...
I think the problem is going to be in the Windows software, and not the settings on the monitor. Not sure which type of computer or which Windows you're running, but get into control panel, monitor settings and see what you can do. Windows help and support might be able to assist you.
Here's an excerpt from ncix.com:
Cons Clumsy front panel controls
Vertically, picture is no larger than my old 17"
May require video card upgrade for higher resolutions
Front panel illuminated power button is distracting
Summary Overall, I really like this monitor. But don't expect a size increase vertically over a 17" display. I actually lost half an inch. I prefer a 16:10 aspect ratio so I'm not actually using the full wide available. If you're like me you can save some change and go for the 2243.
Not sure if that will help, but there it is.
Here is the whole blog:
http://ncix.com/products/index.php?mode=productreviewread&product_id=37490
Not sure if this will help, but you might check it out:
http://www.sevenforums.com/graphic-cards/19981-cannot-display-1920-x-1080-a-2.html
Good luck, and hope this helps.
Sep 20, 2010 | LG Computers & Internet
Blank Space Around Screen
Reduce the resolution a little.
Sep 20, 2017 | Acer H233H bmid Monitor
Sony 24'' CRT widescreen GDM-FW900 blurry after initial on
CRT shorts are common with this model and focus problems are a major symptom. however, the loud 'pop' you described leads me to believe that the flyback transformer may have a problem in the focus divider portion. replace the flyback, if that fails then the CRT is most certainly the problem
Nov 20, 2008 | Sony GDM-W900 24" CRT Monitor
Problem watching movies & playing games(screen flashes black on & off
HI
This may not help, but you can try to lower the resloution to another widescreen format.
I'm thinking you may have your resolution maxed out and the video card is having problems with the movie games because of that. Possibly not enough video memory
Movies will work fine at lower resolutions, Not sure about all the games but they probably will too.
Fran
Oct 15, 2008 | Computers & Internet
"Not support" message when computer hooked up
you may have to mess around with the screen resolutions on the compaq, as your notebook may have a lower screen resolution that your TV can handle, but your Compaq may be above the resolution support of your tv.
Aug 24, 2007 | Akai LCT2721AD 27 in. LCD Television
Sony FW900 24" CRT Monitor Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
